  2. Data
gxdn
By Administrator , 23 January, 2018
Data object is used to save general data, such as configuration data and parameters.
Properties
  • 1. Logical Name
    Logical name of the object.
  • 2. Value
    Value of data object. Value type can be any kind of value type described on DLMS standard.
Actions
There are no actions available for this object type.
Book traversal links for Data
  • ‹ Compact data
  • Up
  • Demand register ›
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv4 setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register activation
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
