currently waiting for my Optical Probe, but I need to read the data from my 3 phase meter & was wondering if anyone had any success?
Comment: In NSW, the meters are not open it seems. Other parts of Australia have open access, but some areas have no open access. In 2028 it is legislated that meters will have open access available, but existing meters may remain restricted.
By searching the net, I think the meter serial number is used as part of the access.
In my opinion, I feel Australia will need to allow read only access to all meters so real time data can be used to control the huge amount of private small batteries (up to 50Kw usually). I feel there is a big need for consumer access to their own data in real time, & the Optical port is a safe, contact free method of reading data. Great work!
Hi, EDMI has sent different…
EDMI has sent different models to us, but not Mk10D s oI can't verify the correct settings. You can try to read your meter with GXDLMSDirector.
Select EDMI as a manufacturer.
interface: HDLC
Logical server : 1
Physica server 23
Serial port settings 9600 8None1
