  2. AttributeError: 'GXXmlWriter' Object Has No Attribute 'WriteEndElement'
AttributeError: 'GXXmlWriter' object has no attribute 'WriteEndElement'
By sgbubble, 18 March, 2025
I'm starting by reading the object list from meter and then saving it in a file, but the saving process is giving me the following error:
File "\AppData\Local\Programs\Python\Python39\lib\site-packages\gurux_dlms\objects\GXDLMSObjectCollection.py", line 253, in save
it.save(writer)
File "\AppData\Local\Programs\Python\Python39\lib\site-packages\gurux_dlms\objects\GXDLMSFunctionControl.py", line 381, in save
writer.WriteEndElement() # Activations
I have successfully save the object's list when there is no function control object so I think it is related to that module. Any ideas?
Thank you in advance.
1 year ago
Hi, Thank you for pointing…
Thank you for pointing this out. This is fixed to version version 1.0.175.
sgbubble
1 year ago
Thank you for your quick…
Thank you for your quick response. Related to Function Control, I have also detected that in GXDLMSConverter.py module methods objectTypeToString() and valueOfObjectType() Function control is missing.
1 year ago
Thank you for pointing this out. This is fixed to version version 1.0.176.
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
  • Mon, 04/13/2026 - 11:39
    Gurux.DLMS.Net 9.0.2604.1301
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
