  2. AttributeError: 'GXXmlWriter' Object Has No Attribute 'WriteEndElement'
AttributeError: 'GXXmlWriter' object has no attribute 'WriteEndElement'
By sgbubble, 18 March, 2025
I'm starting by reading the object list from meter and then saving it in a file, but the saving process is giving me the following error:
File "\AppData\Local\Programs\Python\Python39\lib\site-packages\gurux_dlms\objects\GXDLMSObjectCollection.py", line 253, in save
it.save(writer)
File "\AppData\Local\Programs\Python\Python39\lib\site-packages\gurux_dlms\objects\GXDLMSFunctionControl.py", line 381, in save
writer.WriteEndElement() # Activations
I have successfully save the object's list when there is no function control object so I think it is related to that module. Any ideas?
Thank you in advance.
11 months ago
Hi, Thank you for pointing…
Thank you for pointing this out. This is fixed to version version 1.0.175.
sgbubble
11 months ago
Thank you for your quick…
Thank you for your quick response. Related to Function Control, I have also detected that in GXDLMSConverter.py module methods objectTypeToString() and valueOfObjectType() Function control is missing.
11 months ago
Thank you for pointing this out. This is fixed to version version 1.0.176.
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Landisgyr meter
  • GxDateTime always return DayOfWeek as FF
  • Python GXDLMSTranslator
