  2. AttributeError: 'GXXmlWriter' Object Has No Attribute 'WriteEndElement'
AttributeError: 'GXXmlWriter' object has no attribute 'WriteEndElement'
By sgbubble, 18 March, 2025
I'm starting by reading the object list from meter and then saving it in a file, but the saving process is giving me the following error:
File "\AppData\Local\Programs\Python\Python39\lib\site-packages\gurux_dlms\objects\GXDLMSObjectCollection.py", line 253, in save
it.save(writer)
File "\AppData\Local\Programs\Python\Python39\lib\site-packages\gurux_dlms\objects\GXDLMSFunctionControl.py", line 381, in save
writer.WriteEndElement() # Activations
I have successfully save the object's list when there is no function control object so I think it is related to that module. Any ideas?
Thank you in advance.
11 months 3 weeks ago
Hi, Thank you for pointing…
Thank you for pointing this out. This is fixed to version version 1.0.175.
sgbubble
Thank you for your quick…
Thank you for your quick response. Related to Function Control, I have also detected that in GXDLMSConverter.py module methods objectTypeToString() and valueOfObjectType() Function control is missing.
Thank you for pointing this out. This is fixed to version version 1.0.176.
  • Thu, 02/19/2026 - 11:51
    gurux.dlms.cpp 9.0.2602.1901
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Gurux C library DLMS book edition support
  • Help with connection and read with landis+gyr e650 + CU-E22 using python
  • Preestablished connection
  • RJ11 to RS232 Pin out SECURE Premier 300
  • GENUS sugam 3 PH bidirectional
