  3. HLS Authentication and UpdateSecret
By slip81, 9 November, 2021
I'm trying to change High authentication level password (using C# .NET Gurux library), there's a specific method for this in class GXDLMSAssociationLogicalName:
public byte[][] UpdateSecret(GXDLMSClient client)
I found mentioning of using this method here:
https://www.gurux.fi/comment/10669#comment-10669
According to DLMS/COSEM documentation, before sending to meter - new password (i.e. Secret property) must be encrypted with AES-128 algorithm with current password as an encryption key.
My question is: should I implement my own encryption method for this ? Or is there any built-in option in Gurux library ?
Thanks !
4 years 7 months ago
The password may be encrypted, but it's not required. For this reason, it's sent as plain text.
You can cipher the content with KEK like this:
GXDLMSSecureClient.Encrypt(byte[] kek, byte[] password)
