By fernando, 28 August, 2020 Forums Gurux.DLMS Hi, What compiler do you use for ARM and what operating system? When compiling it gives me the error that appears in the image. Thank you. Image Hi, Hi, I believe that your compiler is not supporting float32 and float64. Open gxignore.h file and un-comment DLMS_IGNORE_FLOAT32 and DLMS_IGNORE_FLOAT64 Let me know if you have any problems. BR, Mikko Hi, Hi, after doing it, now it gives me this error. Image Hi, Hi, in another compiler it gives me this error. Thank you. Image Hi, Hi, What compilers you are using? DLMS_IGNORE_FLOAT64 issue if fixed, but your second looks strange. Get the latest version. BR, Mikko Hi, Hi, We have tested on a debian 10: with the following compiler arm-linux-gnueabi-gcc: COLLECT_GCC=arm-linux-gnueabi-gcc COLLECT_LTO_WRAPPER=/usr/lib/gcc-cross/arm-linux-gnueabi/8/lto-wrapper Target: arm-linux-gnueabi Configured with: ../src/configure -v --with-pkgversion='Debian 8.3.0-2' --with-bugurl=file:///usr/share/doc/gcc-8/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-8 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libitm --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --with-target-system-zlib --enable-multiarch --disable-sjlj-exceptions --with-arch=armv5te --with-float=soft --disable-werror --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=arm-linux-gnueabi --program-prefix=arm-linux-gnueabi- --includedir=/usr/arm-linux-gnueabi/include Thread model: posix gcc version 8.3.0 (Debian 8.3.0-2) AND IT GIVES US THE FOLLOWING ERROR: /gxvalueeventargs.c: In function ‘vec_attach’: src/gxvalueeventargs.c:64:15: warning: assignment to ‘gxValueEventArg **’ {aka ‘struct <anonymous> **’} from incompatible pointer type ‘gxValueEventArg *’ {aka ‘struct <anonymous> *’} [-Wincompatible-pointer-types] arr->data = value; ^ Compiled src/gxvalueeventargs.c successfully! Compiled src/dlmsSettings.c successfully! src/notify.c: In function ‘notify_parsePush’: src/notify.c:278:43: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] arr_push(items, key_init(obj, (void*)(uint64_t)index)); ^ Compiled src/notify.c successfully! Compiled src/message.c successfully! src/variant.c: In function ‘convert’: src/variant.c:1612:37: error: ‘dlmsVARIANT’ {aka ‘struct tagdlmsVARIANT’} has no member named ‘fltVal’; did you mean ‘pfltVal’? sprintf(buff, "%f", tmp.fltVal); ^~~~~~ pfltVal src/variant.c:1628:38: error: ‘dlmsVARIANT’ {aka ‘struct tagdlmsVARIANT’} has no member named ‘dblVal’; did you mean ‘pdblVal’? sprintf(buff, "%lf", tmp.dblVal); ^~~~~~ pdblVal src/variant.c:1763:58: error: ‘dlmsVARIANT’ {aka ‘struct tagdlmsVARIANT’} has no member named ‘fltVal’; did you mean ‘pfltVal’? sscanf((char*)tmp.strVal->data, "%f", &item->fltVal); ^~~~~~ pfltVal src/variant.c:1774:59: error: ‘dlmsVARIANT’ {aka ‘struct tagdlmsVARIANT’} has no member named ‘dblVal’; did you mean ‘pdblVal’? sscanf((char*)tmp.strVal->data, "%lf", &item->dblVal); ^~~~~~ pdblVal make: *** [makefile:33: obj/variant.o] Error 1 WE HAVE ALSO TESTED ON AN UBUNTU 10.04 WITH THE ARM-LINUX-GCC COMPILER: arm-linux-gcc (GCC) 3.3.2 Copyright (C) 2003 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE GETTING THE FOLLOWING ERRORS In file included from src/../include/helpers.h:46, from src/apdu.c:36: src/../include/variant.h:134: warning: declaration does not declare anything Compiled src/apdu.c successfully! In file included from src/../include/helpers.h:46, from src/bitarray.c:44: src/../include/variant.h:134: warning: declaration does not declare anything Compiled src/bitarray.c successfully! In file included from src/../include/helpers.h:46, from src/bytebuffer.c:47: src/../include/variant.h:134: warning: declaration does not declare anything Compiled src/bytebuffer.c successfully! In file included from src/../include/helpers.h:46, from src/ciphering.c:53: src/../include/variant.h:134: warning: declaration does not declare anything Compiled src/ciphering.c successfully! In file included from src/../include/dlmssettings.h:41, from src/../include/apdu.h:36, from src/client.c:44: src/../include/variant.h:134: warning: declaration does not declare anything src/client.c: In function 'cl_getApplicationAssociationRequest': src/client.c:337: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c:338: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c:339: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c:340: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c:341: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c: In function 'cl_parseApplicationAssociationResponse': src/client.c:419: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c:419: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c:458: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c:459: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c: In function 'cl_parseLNObjects': src/client.c:526: error: 'dlmsVARIANT' has no member named 'Arr' src/client.c:530: error: 'dlmsVARIANT' has no member named 'Arr' src/client.c:531: error: 'dlmsVARIANT' has no member named 'Arr' src/client.c:532: error: 'dlmsVARIANT' has no member named 'Arr' src/client.c:533: error: 'dlmsVARIANT' has no member named 'Arr' src/client.c:541: error: 'dlmsVARIANT' has no member named 'Arr' src/client.c:552: error: 'dlmsVARIANT' has no member named 'Arr' src/client.c:557: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c: In function 'cl_parseSNObjects': src/client.c:628: error: 'dlmsVARIANT' has no member named 'Arr' src/client.c:633: error: 'dlmsVARIANT' has no member named 'Arr' src/client.c:634: error: 'dlmsVARIANT' has no member named 'Arr' src/client.c:635: error: 'dlmsVARIANT' has no member named 'Arr' src/client.c:636: error: 'dlmsVARIANT' has no member named 'Arr' src/client.c:658: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c: In function 'cl_writeLN': src/client.c:1592: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c:1592: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c: In function 'cl_methodLN': src/client.c:1736: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c:1736: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c: In function 'cl_methodSN': src/client.c:1782: error: 'dlmsVARIANT' has no member named 'byteArr' src/client.c:1782: error: 'dlmsVARIANT' has no member named 'byteArr' make: *** [obj/client.o] Error 1 WE HAVE ALSO TESTED IT WITH WE HAVE ALSO TESTED IT WITH Ubuntu 16.04 con arm-linux-gnueabi-gcc –version: arm-linux-gnueabi-gcc (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9) 5.4.0 20160609 Copyright (C) 2015 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. COMPILE THE DEVELOPMENT WAS WELL BUT WHEN COMPILING THE CLIENT IT GIVES THIS ERROR Compiled src/getopt.c successfully! Compiled src/connection.c successfully! Compiled src/main.c successfully! src/communication.c: In function 'com_readRowsByEntry2': src/communication.c:1212:9: warning: format not a string literal and no format arguments [-Wformat-security] printf(str); ^ Compiled src/communication.c successfully! /usr/bin/ld: obj/getopt.o: Relocations in generic ELF (EM: 40) obj/getopt.o: error adding symbols: File in wrong format collect2: error: ld returned 1 exit status makefile:26: recipe for target 'bin/gurux.dlms.client.bin' failed make: *** [bin/gurux.dlms.client.bin] Error 1 thanks you Hi, Hi, You need to open gxigone and uncomment this line: #define DLMS_IGNORE_MALLOC or add -DDLMS_IGNORE_MALLOC to the compiler flags. BR, Mikko
Thank you.
Thread model: posix
arr->data = value;
pfltVal
pdblVal
pfltVal
pdblVal
from src/apdu.c:36:
printf(str);
thanks you
