  2. MQTT
MQTT
By Sreya, 30 October, 2024
Gurux.MQTT
I'm working with the Gurux application and using the "MQTT" option using "add a device", but I’m running into an error. Could you help me troubleshoot this issue? Any insights or advice would be greatly appreciated!
Thanks!
Sreya
6 months 3 weeks ago
Hi, I'm working with the…
Error : Connecting with MQTT server failed (NotAuthorized)
This is the error i've been receiving.
Hi, I believe that your MQTT…
I believe that your MQTT server requires authentication and client don't use it.
Try first with MQTT broker that doesn't use authentication.
  • Tue, 05/20/2025 - 08:40
    gurux.dlms.c 9.0.2505.2001
  • Mon, 05/19/2025 - 10:19
    gurux.net.java 1.0.30
  • Mon, 05/19/2025 - 10:00
    gurux.dlms.c 9.0.2505.1901
  • Thu, 05/15/2025 - 16:26
    gurux.dlms.c 9.0.2505.1501
  • Wed, 05/14/2025 - 08:30
    gurux.dlms.c 9.0.2505.1401
  • HDLC Adress resolver configuration
  • Reading all "Data" object type parameter together
  • com_read getting failed for billing profile and instantaneous profile
  • Simulator connection closed
  • Regarding the dlms android project
