  2. MQTT
MQTT
By Sreya, 30 October, 2024
Gurux.MQTT
I'm working with the Gurux application and using the "MQTT" option using "add a device", but I’m running into an error. Could you help me troubleshoot this issue? Any insights or advice would be greatly appreciated!
Thanks!
Sreya
1 year 6 months ago
Hi, I'm working with the…
Error : Connecting with MQTT server failed (NotAuthorized)
This is the error i've been receiving.
1 year 6 months ago
Hi, I believe that your MQTT…
I believe that your MQTT server requires authentication and client don't use it.
Try first with MQTT broker that doesn't use authentication.
  • Mon, 05/11/2026 - 11:07
    Gurux.DLMS.Go 1.0.17
  • Mon, 04/27/2026 - 08:37
    Gurux.DLMS.Go 1.0.16
  • Thu, 04/23/2026 - 13:19
    Gurux.DLMS.Net 9.0.2604.2101
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
