  2. Connect To EDMI Metter
Connect to EDMI metter
By TRƯỜNG , 22 April, 2026
How can I connect my EDMI metter using serial port?
1 month 3 weeks ago
Hi, It depends on which EDMI…
It depends on which EDMI meter you try to read. The default settings should be on the meter manual.
You can try this with Mk7Mi:
Authentication level: None
Logical server: 1
Physical Server 23
Baud rate: 9600
TRƯỜNG
1 month 2 weeks ago
I'm using the MK10E meter ,…
I'm using the MK10E meter , my setting same what you mention but it didn't work.
I'm using my Rs485 to USB to connect the metter with my laptop by COM5. Baurate 9600 , Physical server and logical server is same with you.
Pls rely me as soon as you can, thanks
1 month 2 weeks ago
Hi MK10E is using IEC 62053…
MK10E is using IEC 62053-21 and not DLMS.
https://gurux.fi/DLMSCOSEMFAQ
