  3. Reading Billing Date
By poojash, 29 November, 2021
Known problems
I am trying to read Billing date from meter but i get error "Read object Failed".
TX: 7E:A0:19:03:41:32:3A:BD:E6:E6:00:C0:01:81:00:03:00:00:00:01:02:FF:02:00:B1:48:7E
RX: 7E:A0:1E:41:03:52:05:4F:E6:E7:00:C4:01:81:00:09:0C:07:E5:0B:01:01:00:00:00:FF:80:00:00:F1:3A:7E
using Gurux director i can see value received,
<Data>
<!--2021-11-01 00:00:00-->
<OctetString Value="07E50B0101000000FF800000" />
But using coding how i can call using variable. Following is code for that
int Read_BillingDate(void)
gxRegister BillingDate;
int ret;
char BillingDatesamp1e[]="2021-11-01 00:00:00";
const unsigned char lnc[6] = { 0,0,0,1,2,255};
ret = INIT_OBJECT(BillingDate, DLMS_OBJECT_TYPE_REGISTER, lnc);
GX_OCTECT_STRING(BillingDate.value, BillingDatesamp1e,sizeof(BillingDatesamp1e));
ret = com_read(&BillingDate.base, 2);
printf("Read Error\n\r");
return ret;
printf("BillingDateRead complete\n\r");
printf("BillingDate: %s\n\r",BillingDate.value.pbVal);
return 0;
How I get value using BillingDate.value.pbVal
3 years 5 months ago
Your meter is returning Billing Date as an octetString. You need to change it from byte array to date-time like this:
int ret;
unsigned char BillingDatesamp1e[12] = { 0 };
const unsigned char lnc[6] = { 0,0,0,1,2,255 };
if ((ret = INIT_OBJECT(BillingDate, DLMS_OBJECT_TYPE_REGISTER, lnc)) == 0)
GX_OCTECT_STRING(BillingDate.value, BillingDatesamp1e, sizeof(BillingDatesamp1e));
ret = com_read(BASE(BillingDate), 2);
return ret;
dlmsVARIANT date;
var_init(&date);
cl_changeType(BillingDate.value.byteArr, DLMS_DATA_TYPE_OCTET_STRING, &date);
char str[20];
time_toString2(date.dateTime, str, sizeof(str));
printf("BillingDate: %s\n\r", str);
var_clear(&date);
obj_clear(&BillingDate);
return 0;
poojash
I got this error after adding
I got this error after adding above code you given,
error: 'dlmsVARIANT {aka struct tagdlmsVARIANT}' has no member named 'dateTime'
OK. You are not using malloc. Use this:
int ret;
GX_OCTET_STRING(BillingDate.value, BillingDatesamp1e, sizeof(BillingDatesamp1e));
return ret;
dlmsVARIANT tmp;
gxtime billlingDate;
time_initUnix(&billlingDate, 0);
GX_DATETIME(tmp) = &billlingDate;
gxByteBuffer bb;
BB_ATTACH(bb, BillingDatesamp1e, 12);
if ((ret = dlms_changeType(&bb, DLMS_DATA_TYPE_DATETIME, &tmp)) == 0)
char str[20];
time_toString2(&billlingDate, str, sizeof(str));
var_clear(&tmp);
return 0;
poojash
hi,
hi,
Now getting "undefined reference to `time_toString2'" this error. since I included data.h file
You need to also add data.c -file.
poojash
I dont have data.c file'
Sorry,
Sorry,
You need to also add date.c -file.
poojash
Yes i have already included
Yes i have already included it
I don't know what is data.h. time_toString2 is in date.h. Have you added it date.h?
poojash
Yes i have added date.h file
poojash
Is there any other method to get Billing date using "0,0,0,1,2,255" this OBIS code
poojash
I am using ATSAME54 board to read data from meter. I checked date.c file. There is condition
"#if !defined(GX_DLMS_MICROCONTROLLER)" to use "time_toString2() ". So please help what should i have to do.
poojash
Thanks for the support I got
Thanks for the support I got time in string.
poojash
I used strftime() function to
I used strftime() function to convert the time.
I'm glad that you solved this.
I was thinking this and it might be good if time_toString2 is available even GX_DLMS_MICROCONTROLLER is defined. It might be handy in some cases.
It will be available in the next version.
  • Fri, 05/09/2025 - 13:03
    Gurux.DLMS.Python 1.0.181
  • Wed, 05/07/2025 - 16:09
    Gurux.DLMS.Android 2.0.14
  • Tue, 05/06/2025 - 09:34
    gurux.dlms.c 9.0.2505.0601
  • Tue, 05/06/2025 - 08:51
    GXDLMSDirector 9.0.2505.0601
  • Tue, 05/06/2025 - 08:26
    gurux.dlms.java 4.0.79
  • +27734583119 WORLD'S TOP BEST LOTTO SPELLS AUSTRALIA ITALT UK USA SCOTLAND NETHERLANDS CHICAGO POLAND MEXICO COLORADO NORWAY
  • CRYPTO SCAM RECOVERY - HIRE iBOLT CYBER HACKER COMPANY
  • +27734583119 TRUSTED IMPACTFUL BLACK MAGIC RING AND PURSE FOR WEALTH FAME SUCCESS FRANCE AUSTRALIA ITALY UK USA SCOTLAND QATAR WASHINGTON POLAND MIAMI NEW YORK INDONESIA ALABAMA ARIZONA
  • +27734583119 MOST CONSTRUCTIVE BLACK MAGIC DEATH SPELLS CASTER FRANCE CANADA AUSTRALIA ITALY UK USA QATAR WASHINGTON BOTSWANA CHICAGO PORTUGAL LEBANON BERLIN
  • +27734583119 BLACK MAGIC GET BACK LOST SPELLS DENMARK LONDON AUSTRALIA NORWAY USA SCOTLAND SPAIN QATAR
  • Grace Harrison
  • diegovalentin7
  • mamanandi
  • nnn
  • raghavrg09
