  3. Code For Secure Energy Meter Using Nodemcu and Show All Reading On LCD
Code for Secure Energy meter using Nodemcu and Show all reading on LCD
By ayushshriwastav, 1 November, 2022
Known problems
How can i make a code for display reading on lcd of energy meter by OBIS Code using Nodemcu. Can you suggest or link to me for making code for Secure meter?
3 years 1 month ago
The example reads the clock object. Find //Read clock.
It also prints date and time for the serial port using GXTRACE.
You need to add register objects in the same way as the clock object has been added.
The problem at the moment is that one of your settings is different than the meter expects.
Try to connect with GXDLMSDirector for your meter. It will help you to get a better idea of DLMS meters.
ayushshriwastav
3 years 1 month ago
Thanks sir for reply. My question is not that use gxtrace or com_AllObject. My question is that what should i write read value in gxtrace or com_retAllObject and How should i write read value in gxtrace.?
for example, Can i write syntax in void loop() in Arduindo in given below-
ret = gxtrace("1.0.99.1.0.255") or not? please tell me syntax to read value of register and clock in void loop()?
Thanks Sir,
3 years 1 month ago
gxtrace is send to write a trace. You don't use it for the communication. You can think that gxtrace equals Console.WriteLine. It's used to print the value, not for the communication.
Check this. It will read the date and time from the clock object and then write the content of the clock object for the meter.
//Read clock
gxClock clock1;
cosem_init(BASE(clock1), DLMS_OBJECT_TYPE_CLOCK, "0.0.1.0.0.255");
com_read(BASE(clock1), 3);
com_read(BASE(clock1), 2);
obj_toString(BASE(clock1), &data);
GXTRACE(GET_STR_FROM_EEPROM("Clock"), data);
obj_clear(BASE(clock1));
free(data);
ayushshriwastav
3 years 1 month ago
Thanks for replying sir, How can i read value of Register and Extended Register in void loop() function in Arduino? What is syntax of Register and Extended register in void loop() function?
Thanks sir
3 years 1 month ago
Add values that you want to read under the clock object. Something like this:
//Read register
gxRegister reg1;
cosem_init(BASE(reg1), DLMS_OBJECT_TYPE_REGISTER, "YOUR_OBIS_CODE");
com_read(BASE(reg1), 3);
com_read(BASE(reg1), 2);
obj_toString(BASE(reg1), &data);
GXTRACE(GET_STR_FROM_EEPROM("Register"), data);
obj_clear(BASE(reg1));
free(data);
ayushshriwastav
3 years 1 month ago
Thank you so much for replying sir . How can i find InvocationCounter for Secure Meter?
Please tell me about InvocationCounter for Secure meter? How can I find it and What is role of Invocation Counter in DLMS Meter?
Thank you sir
3 years 1 month ago
When you connect to the meter there should be an Invocation Counter data object. It's used to improve security, but all meters don't use it.
ayushshriwastav
3 years 1 month ago
I am very happy to hear for reply sir , thank you so much sir. If Some meter don't use Invocation Counter then What should i write in " ret = com_readAllObjects("0.0.43.1.0.255") " in the void loop()
3 years 1 month ago
Set it NULL if you don't want to use Invocation Counter.
com_readAllObjects(NULL);
ayushshriwastav
3 years 1 month ago
Thanks for replying sir. I have found new error in NodeMCU Board in Arduino IDE when clock and register define in void loop() function in given below. How can I solve this sir?
Arduino: 1.8.18 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
3 years 1 month ago
You need to define data variable like this:
char* data = NULL;
ayushshriwastav
3 years 1 month ago
Thank you so much sir. It is working perfectly and i did make it Global Variable char* data = NULL;
I have some question now that if i want to read more values of Register for example reg2, reg3, reg4 and reg5 etc. So what will syntax be written in void loop() function for reg2,reg3,reg4 etc??
3 years 1 month ago
Check my answer:
https://www.gurux.fi/comment/25325#comment-25325
ayushshriwastav
3 years 1 month ago
Thanks for reply sir. I am receiving this error again after convert object to string function obj_toString() in void loop() function in arduino ide in given below. Where am i going wrong ? Please tell me real solution.
3 years 1 month ago
It's a little hard to say from your pics, but you need to set data to NULL after free.
free(data);
data = NULL;
ayushshriwastav
3 years 1 month ago
Thanks for replying sir. I am very happy that you are guiding well sir. I am attaching code of void loop() function of client.ino in given below - and please tell me this is Right or Wrong?
void loop()
int ret;
// Read the clock
gxClock clock1;
if (millis() - runTime > 5000)
runTime = millis();
GXTRACE(GET_STR_FROM_EEPROM("Start reading"), NULL);
//TODO: Change logical name of the frame counter if it's used.
ret = com_readAllObjects(1.0..43.1.0.255);
com_close();
3 years 1 month ago
It looks correct to me.
ayushshriwastav
3 years 1 month ago
Thanks for replying sir. Very nice responsive talking. I have added more register whose name is reg2,reg3,reg4 in given below code. what is this correct code or not because i am taking register value in same time and declare global variable char* data = NULL; So please brief explain how is storing reg1,reg2,reg3 and reg4 in data in same time? And please tell sir this code is correct or not in given below-
client.ino
int ret;
// Read the clock
gxClock clock1;
//Read the Register
gxRegister reg1;
gxRegister reg2;
gxRegister reg3;
gxRegister reg4;
3 years 1 month ago
This is the correct way to do it. You aren't reading the values with the same request. You can use readList to read multiple values with one request, but all the meters don't support it.
ayushshriwastav
3 years 1 month ago
Thanks for reply sir, Can you please suggest and give syntax me How can use readList to read multiple values in code?
And also brief tell sir if meter don't support it then what should be do for it?
3 years 1 month ago
com_readScalerAndUnits do what you want to do.
https://github.com/Gurux/GuruxDLMS.c/blob/c65175efc8917f0ee3a7eb340ac4e…
If that is not supported then you need to read objects one by one as you do now.
ayushshriwastav
3 years 1 month ago
Very thank you so much. Very nice talking and I am very happy that you are very helpful sir. Can you please tell how can read all value in com_readScalerAndUnits()? Please can you write a syntax to read all value in com_readScalerAndUnits().
3 years 1 month ago
I believe that you don't want to read all values. It's taking a long time, but this does it.
3 years 1 month ago
ayushshriwastav
2 years 12 months ago
Hi, Thank you, But i am not…
Thanks for helping but i didn,t get ouput. Sure, I will find.
Pagination
  • First page
  • Previous page
  • Page 1
  • Page 2
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Thu, 12/11/2025 - 13:22
    Gurux.DLMS.Python 1.0.194
  • 6-digit field values from meter not fully received (only 5 digits shown)
  • Gurux DLMS Android App
  • FRANCISCO
  • Supun Ellewela
  • Mario
  • brianmon
  • dejanm
