By socketmanager1337 , 31 March, 2026 Forums General discussion Are there any example implementations of DLMS/COSEM servers that use ECDSA for High-Level Security (HLS) authentication? Hi, You can use https:/… Hi, You can use https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Server.E… You need first to establish a connection with High authentication and update the client certificate to the meter. You can do this with a client example using -N 0.0.43.0.7.255 BR, Mikko
You can use
