  2. GetRequestWithList Translator Error
GetRequestWithList Translator error
By andre538, 19 January, 2026
Hello Mikko,
any news about GetRequestWithList Translator error?
Unfortunately can't comment old post, so decided to create new one.
Br, Andrew
andre538
2 months 3 weeks ago
Initial question dated as 25…
Initial question dated as 25 November, 2025
Hi Andrew, This is fixed in…
Hi Andrew,
This is fixed in the next version. The expected release data is 4. February.
The updated code is below. Thank you for pointing this out.
if (reply.Xml != null)
GXDataInfo di = new GXDataInfo();
di.xml = reply.Xml;
//Data.
reply.Xml.AppendStartTag(Command.ReadResponse, SingleReadResponse.Data);
GXCommon.GetData(settings, reply.Data, di);
reply.Xml.AppendEndTag(Command.ReadResponse, SingleReadResponse.Data);
reply.ReadPosition = reply.Data.Position;
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • Tue, 04/07/2026 - 14:50
    gurux.dlms.java 4.0.91
  • Tue, 04/07/2026 - 14:00
    Gurux.DLMS.Net 9.0.2604.0701
  • Mon, 03/30/2026 - 15:39
    gurux.dlms.c 9.0.2603.3001
