  2. Regarding The Dlms Android Project
Regarding the dlms android project
By atuldd, 27 October, 2025
Gurux DLMS for Android
I am working in a project where need to communicate with NON DLMS meters that use the IEC 62056-21
Is it possible if Gurux serial can be used to handle the communication
6 months 2 weeks ago
Hi, Yes, you can use Gurux…
Yes, you can use Gurux Serial. You just need to set the correct serial port settings.
atuldd
6 months 1 week ago
Hi Mikko, Can we use…
Can we use GXDLMSDirector or Gurux DLMS library to communicate with non-DLMS meters that follow the IEC 62056-21 protocol?
The reason I ask is that the request and response format in non-DLMS IEC 62056-21 meters is different from DLMS meters.
Also, is it possible to communicate with such non-DLMS meters from an Android application using Gurux libraries?
6 months 1 week ago
Hi, No, you can't. DLMS and …
No, you can't. DLMS and IEC 62056-21 are two totally different protocols.
You can get more information by reading: IEC 62056-21 is not DLMS/COSEM:
https://gurux.fi/DLMSCOSEMFAQ
  • Mon, 05/11/2026 - 11:07
    Gurux.DLMS.Go 1.0.17
  • Mon, 04/27/2026 - 08:37
    Gurux.DLMS.Go 1.0.16
  • Thu, 04/23/2026 - 13:19
    Gurux.DLMS.Net 9.0.2604.2101
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
