  2. Physical Addres
Physical addres
By ksk , 21 October, 2025
Hi.
I have a device with a physical address of 6538. I'm setting this address in GURUXDirector. But in the command line parameters, this address looks like "-s 22922" What's the formula for converting 6538 to 22922?
7 months 3 weeks ago
Hi, What meter do you try to…
What meter do you try to read? I believe that you are using a serial number where the address is counted from the serial number, and you don't give the direct physical address. Is that the case?
