  2. Setting Up Agent
Setting up agent
By Note5 , 22 September, 2025
Gurux.DLMS.AMI
I have downloaded the agent zip folder and tried following to instructions to setup the agent as from the terminal output below
PS F:\PROJECTS\HARDWARE\POWER\agent_4.0.2409.1101> dotnet Gurux.DLMS.AMI.Agent.dll
starting Gurux.DLMS.Agent version 4.0.2409.1101
Welcome to use Gurux.DLMS.AMI.
Gurux.DLMS.AMI address: [https://localhost:8001]
https://185.239.208.202:8001
Enter agent name: [I-32]
Enter Personal Access Token:
D13B69E1D9C0A9FC3EB7956E7993416FFFC35A48E414330904170275BB3FCB4D
fail: Gurux.DLMS.AMI.Agent.Program[0]
The SSL connection could not be established, see inner exception.
I get that exception yet I can access the AMI I have installed online. Also is the Personal Access token same as the generated token in the agent add page?
8 months 3 weeks ago
Hi, Yes, PET is the token…
Yes, PET is the token you generated when you add the agent.
Check your URL. Read also this:
https://www.gurux.fi/Gurux.DLMS.AMI4/QuickStart
