  2. Issue Connecting Smart Meter Via Optical Probe On Android (Invalid Logical Name / Limited Data Issue)
Issue Connecting Smart Meter via Optical Probe on Android (Invalid Logical Name / Limited Data Issue)
By Suraj Pandey , 30 August, 2025
Gurux DLMS for Android
Hi Gurux Team,
I am trying to connect a smart meter using an optical probe with an Android phone
through the Gurux DLMS Android App.
Case 1 (Error: Invalid Logical Name)
When I configure the connection with these parameters:
Manufacturer: India Standard
Referencing: Logical Name
Interface: HDLC
Password: [Provided]
Wait Time: 30:00
Address Type: Default
Physical Address: 1
Logical Address: 0
Authentication: US
Client Address: 48 / 16 / 30
Security Policy: Authentication + Encryption
Suite: 0
Block Cipher Key: [Provided]
Authentication Key: [Provided]
Client System Title: [Provided]
I receive the error:
Invalid logical name
Case 2 (Successful Connection but Limited Data)
When I use these parameters instead:
Interface: HDLC
Authentication: PC
Wait Time: 30:00
Physical Address: 1
Logical Address: 0
Client Address: 16
Security Policy: None
Suite: 0
The app connects to the meter, but I only get limited data. I would like to retrieve additional datasets.
My Questions :
Why does Case 1 fail with Invalid Logical Name, while Case 2 connects but with limited data?
How can I configure the Gurux DLMS Android App to access all available meter data?
Do I need to fill in the following fields for my use case, and if yes, what values should be used?
Invocation Counter
Challenge
Dedicated Key
Server System Title
