  2. Regarding The Dlms Android Project
Regarding the dlms android project
By atuldd, 28 July, 2025
Gurux DLMS for Android
i am using gurux android project where not able to connect with the usb prob
prob details given below
man info:Silicon Labs:CP2102
USB to UART bridge controller
chipset:CP21XX
serial:0001
Boud rate:9600
data bits:8
parity :none
stop bits :1
9 months 1 week ago
Hi, Are you getting any…
Are you getting any reply from the meter? Try to connect with GXDLMSDirector first.
There are a lot of settings that might be the reason why your meter does not reply. For example, the baud rate might be wrong.
  • Mon, 05/11/2026 - 11:07
    Gurux.DLMS.Go 1.0.17
  • Mon, 04/27/2026 - 08:37
    Gurux.DLMS.Go 1.0.16
  • Thu, 04/23/2026 - 13:19
    Gurux.DLMS.Net 9.0.2604.2101
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
