By supritha , 25 July, 2025 Forums General discussion Hi, when I am trying to communicate with the meter, I am facing issue at 7th transmission I am getting error code response from the meter as read write denied. could you assist with this issue. Regards Supritha K P Hi, I believe the object you… Hi, I believe the object you try to read does not exist on the meter. Check that the logical name and object type are correct. BR, Mikko
