  2. How To Limit Frame Size On Client Side?
how to limit frame size on client side?
By abk964, 13 May, 2025
Gurux DLMS for ANSI C
Strange device works in "Director" only if checkbox "use frame size" is checked in "device properties".
How to set same option in C library?
Or is there other way to limit frame size?
12 months ago
Hi, Set maxInfoTX and…
Set maxInfoTX and maxInfoRX to the settings like this:
con.settings.maxInfoTX = 60;
abk964
11 months 4 weeks ago
Hi. Thanks. Have found my…
Hi.
Thanks. Have found my own mistake.
More detailed: any value of maxInfoTX and maxInfoRX except 128 will be passed in SNRM request.
Director sends 0x75 and 0x72 if checkbox "use frame size" is checked.
11 months 3 weeks ago
Hi, The use of frame size…
The use of frame size was used to fix the one-meter model issue. Don't use it if you don't have to.
The default values (128) are not sent in SNRM.
  • Mon, 05/11/2026 - 11:07
    Gurux.DLMS.Go 1.0.17
  • Mon, 04/27/2026 - 08:37
    Gurux.DLMS.Go 1.0.16
  • Thu, 04/23/2026 - 13:19
    Gurux.DLMS.Net 9.0.2604.2101
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
