  2. MBUS Diagnostic
MBUS Diagnostic
By Alinj, 13 May, 2025
In Gurux GXDMS Director tool, I tried to refresh objects to read all the objects from my meter, the new objects has been added to the list, but when I try to select and read them, I receive this error:
ERROR: The given key was not present in the dictionary.
Also the new object is MBUSDIAGNOSTIC
I would be grateful if you can help me with this problem.
Alinj
7 months ago
I need to solve this problem…
I need to solve this problem as soon as possible
thank you in advance.
7 months ago
Hi, The MBUS Diagnostic UI…
The MBUS Diagnostic UI is not implemented to the GXDLMSDirector. I'll add that to the worklist, but I can't say when it's released.
Alinj
7 months ago
I was successful in reading…
I was successful in reading with gurux.DLMS.Client.example
Do you think I can also write this object using the same sample?
7 months ago
Hi, Yes, you can write the…
Yes, you can write the MBUS diagnostic object with the client example.
Alinj
7 months ago
I did it thanks
I did it thanks
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Thu, 12/11/2025 - 13:22
    Gurux.DLMS.Python 1.0.194
  • Thu, 12/11/2025 - 11:01
    gurux.dlms.java 4.0.86
  • Wed, 12/10/2025 - 08:45
    gurux.dlms.java 4.0.85
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Inhemeter i210 dlms director
  • Gurux.Net
  • GXTIME Conversion Issue
  • DLMS Meter Gurux DLMS Director Properties
  • Using MAX3232 + FT232RL to Energy meter with GXDLMS Director
