  2. Not Enough Memory Available. (ReadObject Failed) COM_READ
Not enough memory available. (ReadObject failed) COM_READ
By Somesh_8073, 17 April, 2025
Gurux DLMS for ANSI C
hello,
I am trying to read ProfileGeneric - Meter Block Load Profile 1.0.99.1.0.255 using DLMS C library. I get Not enough memory available.
com_read --> com_readDataBlock --> readDLMSPacket --> cl_getData
this is the flow and cl_getData stating above "not enough memory "error.
TRACE for your reference sir, ----------------------------------------------------
[uart_send_data]---> Packet Sending: 7e: a0: 26: 03: 61: fe: 62: 6c: e6: e6: 00: c8: 18: 30: 00: 00: 00: 30: 0a: 75: 24: 78: d5: 94: 98: 54: bf: e8: 22: ea: 60: de: 42: dc: c9: 32: 67: 85: 09: 7e
[17:37:33.438] [uart_interrupt_callback]Complete Packet Received
[17:37:33.464] [com_read]com_read failed Not enough memory available.
[17:37:33.464] [uart_send_data]---> Packet Sending: 7e: a0: 5f: 03: 61: 10: 34: c1: e6: e6: 00: c8: 51: 30: 00: 00: 00: 31: 56: 69: 1f: 7a: 18: 3b: 7e: 46: 34: 9f: 9f: 95: ed: de: 34: 19: b9: 6f: 62: 89: c8: 74: 8a: 20: f3: 9a: dd: c0: 67: f8: 44: 42: 39: 5c: 29: d5: 97: 14: 0d: da: 26: bb: 76: 48: ec: 29: 6a: e1: 4d: 76: 87: d6: 8a: 3f: 52: 57: 43: d9: 46: 27: db: d2: 77: 29: b8: 04: 1f: 61: 19: 4c: 46: c4: 9a: 08: 1c: d0: 69: 42: 7e
[17:37:34.057] [uart_interrupt_callback]Complete Packet Received
[17:37:34.483] [com_readRowsByRange]com_readRowsByRange failed Invalid parameter.
[17:37:37.481] [uart_send_data]---> Packet Sending: 7e: a0: 36: 03: 61: 32: a3: a3: e6: e6: 00: 62: 28: 80: 01: 00: be: 23: 04: 21: 21: 1f: 30: 00: 00: 00: 32: 69: b1: 13: ed: b3: cf: ec: e2: a5: c9: 7b: f9: 64: fd: 1a: 73: 82: 32: fe: a1: dd: e7: 90: 57: 37: 94: d6: 13: 7e
[17:37:37.681] [uart_interrupt_callback]Complete Packet Received
[17:37:38.523] [uart_send_data]---> Packet Sending: 7e: a0: 07: 03: 61: 53: 65: 81: 7e
[17:37:38.729] [uart_interrupt_callback]Complete Packet Received
1 year ago
Hi, I need the block cipher…
I need the block cipher key to decrypt the message.
Somesh_8073
1 year ago
hello, Block Cipher Key - …
hello,
Block Cipher Key - DgVcL03iNt18SmPj
Thank You
1 year ago
Hi, I also need the AARQ and…
I also need the AARQ and AARE messages. Make the connection to the meter and add the first four messages here.
Somesh_8073
1 year ago
hello, TRACE for your…
hello,
TRACE for your reference sir ------------------>
[Trace removed]
1 year ago
Hi, It looks like your meter…
It looks like your meter is returning invalid data for com_readRowsByRange.
Because meter replies are missing, I can't check the reason.
I noticed that your start and end times are the same. Check that. It might help.
Somesh_8073
1 year ago
hello,sir start time and end…
hello,sir
start time and end time are not same, we are trying to read data of 1 hour.
TRACE for your reference sir ------------------> can you please check one more time, below logs
[Trace removed]
Somesh_8073
11 months 3 weeks ago
HI, can you just help me out…
HI,
can you just help me out with the function name ?
when we are trying to read instantaneous profile using DLMSDirector, by chossing "ALL" option to read data, we are able to read data on dlmsdirector.
but in code ByRange & ByEntry function are not able to read, is there any other function which is used to read all data of "instantaneous Profile".
Hi, Your meter is returning…
Your meter is returning invalid data. You need to ask meter manufacturer to fix it. Please, create a new topic if you have a new question.
You can read the instant profile only with all because there is only one row.
I'll remove the hex trace so this is easier to read.
  • Mon, 05/11/2026 - 11:07
    Gurux.DLMS.Go 1.0.17
  • Mon, 04/27/2026 - 08:37
    Gurux.DLMS.Go 1.0.16
  • Thu, 04/23/2026 - 13:19
    Gurux.DLMS.Net 9.0.2604.2101
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
