  2. GuruX Java Simulator For Landis+Gyr Meters
GuruX Java Simulator for Landis+Gyr meters
By PiotrA, 1 April, 2025
I try to use gurux java simulator to create some Landis+Gyr meters with almost the same specification as real meters using: https://github.com/Gurux/gurux.dlms.java/tree/master/gurux.dlms.simulat…
I would like to test if simulated meters are served correctly and if I can actually obtain data (registries, clock, readings etc.) in GXDLMSDirector. I will need it for integration and unit tests of my application.
I encountered 2 problems:
1. I cannot create meters with 'short name referencing', even if I see in console 'DLMS HDLC Short Name simulator start in ports 1000-1009.'
Simulator run parameters: -p 1000 -x mytestdevice.xml -t Info -N 10 -r sn
GXDLMSDirector command line parameters: -h 127.0.0.1 -p 1000 -r sn -n 55980097 -w 1 -f 128 -t Verbose
In GXDLMSDirector I see error: "Connection is permanently rejected. The application context name is not supported. Meter expects Logical Name referencing"
2. Negotiated conformance is only 'GET'. I would like to have also Read, Write, MultipleReferences, basically as much as I can, is it even possible?
Is it related to authentication level? Because it looks like I cannot make any other authentication than 'NONE' using GXDLMSDirector.
Any help will be really appreciated.
Best Regards,
Piotr
1 year ago
Hi, You need to read real…
You need to read real Landis+Gyr meters that use short name referencing. You can't use short name referencing if your meter is using logical name referencing.
PiotrA
1 year ago
Thank you for the response,…
So i have some real Landis+Gyr meters and I connect to those using short name referencing. In GXDLMSDirector I connect to this meter, right click on it and 'Read Object', then I 'Save values as' a MyMeter.xml file. Then i put this file simulator as a parameter together with '-r sn' so i expect short name referencing communication.
When I try to connect to simulated meter using GXDLMSDirector (or trying to call it in java code, doesn't matter) I see 'Meter expects Logical Name referencing'.
Below is what I got from the meter for GXDLMSAssociationShortName and GXDLMSAssociationLogicalName, I have no idea what am I missing here...
<GXDLMSAssociationShortName>
<SN>64000</SN>
<LN>0.0.40.0.0.255</LN>
<Description>Ch. 0 Current association</Description>
<Access>13</Access>
<MethodAccess>11111111</MethodAccess>
<Secret/>
<SecuritySetupReference/>
</GXDLMSAssociationShortName>
<GXDLMSAssociationLogicalName>
<LN>0.0.40.0.1.255</LN>
<Version>1</Version>
<Description>Ch. 1 Association</Description>
<Access>111111010</Access>
<MethodAccess>0000</MethodAccess>
<ClientSAP>16</ClientSAP>
<ServerSAP>1097</ServerSAP>
<ApplicationContextName>
<JointIsoCtt>96</JointIsoCtt>
<Country>133</Country>
<CountryName>116</CountryName>
<IdentifiedOrganization>5</IdentifiedOrganization>
<DlmsUA>3</DlmsUA>
<ApplicationContext>1</ApplicationContext>
<ContextId>1</ContextId>
</ApplicationContextName>
<XDLMSContextInfo>
<Conformance>524288</Conformance>
<MaxReceivePduSize>832</MaxReceivePduSize>
<MaxSendPduSize>65535</MaxSendPduSize>
<DlmsVersionNumber>6</DlmsVersionNumber>
<QualityOfService>0</QualityOfService>
<CypheringInfo/>
</XDLMSContextInfo>
<AuthenticationMechanismName>
<DlmsUA>8</DlmsUA>
<AuthenticationMechanismName>2</AuthenticationMechanismName>
<MechanismId>0</MechanismId>
<Secret>some_secret_password</Secret>
<AssociationStatus>2</AssociationStatus>
<SecuritySetupReference>0.0.0.0.0.0</SecuritySetupReference>
</GXDLMSAssociationLogicalName>
Please let me know if I can provide more details to help you understand the issue.
Best regards,
Piotr Almaszy
1 year ago
Hi, You need to read your…
You need to read your meter with the simulator and not GXDLMSDirector.
-c 16 -s 1 -h [Meter IP Address] -p [Meter Port No] -r sn -o meter-template.xml
PiotrA
1 year ago
Hi, Case 1: When I run…
Case 1: When I run Simulator locally with run parameters: -p 1000 -x testdevice.xml -t Info -N 10
I am able to read meter with parameters: -c 16 -s 1 -h 127.0.0.1 -p 1000 -o testdevice2new.xml (so using logical name referencing)
It is ok.
Case 2: When I run Simulator with parameters: -p 1000 -x testdevice.xml -t Info -N 10 -r sn
Trying to read meter with parameters: -c 16 -s 1 -h 127.0.0.1 -p 1000 -o testdevice2new.xml -r sn (so using shortname referencing)
I see that Logical Name referencing is required anyway...
'The application context name is not supported. Meter expects Logical Name referencing.'
Log from the console:
Authentication: None
ClientAddress: 0x10
Standard: DLMS
gurux.dlms.GXDLMSException: Connection is permanently rejected
at gurux.dlms.GXAPDU.parsePDU2(GXAPDU.java:909)
at gurux.dlms.GXAPDU.parsePDU(GXAPDU.java:838)
at gurux.dlms.GXDLMSClient.parseAareResponse(GXDLMSClient.java:959)
at com.kmd.hesmeterdatareader.dlms.simulator.GXDLMSReader.initializeConnection(GXDLMSReader.java:547)
at com.kmd.hesmeterdatareader.dlms.simulator.GXDLMSReader.readAll(GXDLMSReader.java:938)
at com.kmd.hesmeterdatareader.dlms.simulator.Simulator.readSimulatedValues(Simulator.java:129)
at com.kmd.hesmeterdatareader.dlms.simulator.Simulator.main(Simulator.java:266)
Can it potentially be a bug? Can it be a problem with my testdevice.xml configuration? (It would be weird because this is real meter to which I am able to connect in real world using short name referencing)
Best regards,
Piotr Almaszy
PiotrA
1 year ago
Hi, I just want to bump my…
I just want to bump my question from previous post just in case you missed it and I have another one.
Another question: Is it possible to have no security and have negotiated conformance with more methods than only "GET"?
I need at least "Read", "Write" and "MultipleReferences" is it doable with the simulator on any security level? I Cannot see any configuration in the code for meter conformance.
I will be grateful for any kind of help here.
Best Regards,
Piotr
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
  • Mon, 04/13/2026 - 11:39
    Gurux.DLMS.Net 9.0.2604.1301
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
