I am reading 1.6.0 Extended Register and it has "value", "capture time" and "status" fields. Due to the register's unit is ActiveEnergy, I will have two "values" (one the value field and the status field) with ActiveEnergy unit. How can I seperate one from the other?
Also what is "status" supposed to mean? What does is it record for?
You are reading the meter using IEC 62056-21 and it doesn't define the content of the data. Each manufacturer might have its own way to show this information and you need to ask for the meter manufacturer.
I don't think I am using IEC
I don't think I am using IEC 62056-21 while reading it. It is just to format. I need to know what the status field is for.
Your format is using IEC 62056-21 format. Get more information extended register:
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSExtendedRegister
