Which compiler should we can use
2 posts / 0 new
Last post
poojash
Can development files of dlms and communication and connection files of source and hex file can support XC32 compiler with MPLAB X IDE for SAME54 Xplained board.
Kurumi's picture
Source codes should be compilable in all ANSI C compilers. The only thing that changes is how data is sent and received from UART, TCP/IP port, etc. You need to handle that.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
