Hi Gurux
I have a wierd thing happening when I read an L&G Meter with the AMI.
I read the LP1 ProfileGeneric, and I see this in the agent-logs:
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: info: Gurux.DLMS.AMI.Agent.Worker.GXAgentWorker[0]
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 2
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 8
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 5
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 6
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 3
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 7
May 11 06:45:38 sarelgx02v.elnet.local GuruxAMIAgent[1086]: Ignoring attribute 4
It seems it is ignoring everything.
Hi, Did you add them…
Did you add them manually or use the existing template?
This is checked and I'll let you know later today.
I created a template device…
I created a template device in GXDLMSDirector, imported as template in AMI and created the device based on the template
Hi, Is your meter using…
Is your meter using Short name or logican name referencing?
Let me know this, and this is tested.
Meter is L&G, and is using…
Meter is L&G, and is using Short Name
Hi, Short name referencing…
Short name referencing is tested after lunch. I'll keep you posted.
Hi, This is fixed, and the…
This is fixed, and the new version will be released tomorrow.
