  2. ISKRA ME372 CONNECTION BY DLMSDIRECTOR
By savas, 21 April, 2026
I USE YOUR SOFTWARE TO CONNECT ISKRA ME372 . I TRY DIFFERENT SETTINGS BUT ITS NOT CONNECT . YOU HAVE A DATA ABOUT CONNECT THIS METER WITH OPTICAL PORT
INTERFACE:
AUTHENTICATION:
PASSWORD:
ADRESS:
LOCAL SERVER:
CLIENT ADRESS
LOGICAL DEVICE:
BAUD RATE:
DATA BITS:
PARITY:
STOP BITS:
CAN YOU GIVE THESE PARAMETERS PLEASE .
2 weeks 6 days ago
Hi, If you are using an…
If you are using an optical port, select Iskra as a manufacturer and then change Interface from HDLC to HdldWithModeE.
  • Mon, 05/11/2026 - 11:07
    Gurux.DLMS.Go 1.0.17
  • Mon, 04/27/2026 - 08:37
    Gurux.DLMS.Go 1.0.16
  • Thu, 04/23/2026 - 13:19
    Gurux.DLMS.Net 9.0.2604.2101
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
