  2. Issue When Reading Itron Type620 Meter
Issue when reading Itron Type620 meter
By gegaroms, 9 April, 2026
Dear support,
I'm trying to read a new Itron meter EM600 typeE620.
I fixed parametres as SL7000 or ACE6000 but when start communication i got an error message: (Manufacturer type does not match. Manufacturer is ITE and it should be ACE)
It's not yet supported or i miss somethings.
Thank you for help
Best Regards
1 month ago
Hi, You have used Actaris…
You have used Actaris Electricity as a manufacturer. There are no manufacturer settings for the Itron at the moment. You can create it by yourself.
We don’t have an Itron meter available, so it’s difficult to configure it with the correct settings. The easiest approach would be for you to create the manufacturer settings file for Itron.
You can read instructions from here:
https://www.gurux.fi/GXDLMSDirector.Manufacturers
  • Mon, 05/11/2026 - 11:07
    Gurux.DLMS.Go 1.0.17
  • Mon, 04/27/2026 - 08:37
    Gurux.DLMS.Go 1.0.16
  • Thu, 04/23/2026 - 13:19
    Gurux.DLMS.Net 9.0.2604.2101
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
