  2. Clou Meter CL730D22L Connection
Clou Meter CL730D22L connection
By MetersAdv, 11 March, 2026
I am trying to connect to Clou Meter CL730D22L using RS485 cable and Optical prop cable to this meter but every time I got no response from the meter, can you help on what is the best way to connect to this meter
I have used 9600 8None1 to connect as default but no response
4 days 2 hours ago
Hi, Try to change the…
Try to change the interface from HDLC to HdlcWithModeE and try to connect.
If you are not receiving anything change interface type back to HDLC and try to change the baud rate. I believe that after you have the correct baud rate you can read your meter.
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • Tue, 04/07/2026 - 14:50
    gurux.dlms.java 4.0.91
  • Tue, 04/07/2026 - 14:00
    Gurux.DLMS.Net 9.0.2604.0701
  • Mon, 03/30/2026 - 15:39
    gurux.dlms.c 9.0.2603.3001
