  2. Change Metering Mode In Python
Change Metering Mode in Python
By Kumaresh, 7 August, 2025
Hi Kurmi Ji,
pls Guide how Can I Change the Attribute index 2 of this OBIS 0.0.94.96.19.255.
as i want Read as well as i want to update the value in the meter by 1.
presently the value is 0
def write(self, item, attributeIndex):
data = self.client.write(item, attributeIndex)
self.readDLMSPacket(data)
def read(self, item, attributeIndex):
data = self.client.read(item, attributeIndex)[0]
reply = GXReplyData()
self.readDataBlock(data, reply)
#Update data type on read.
if item.getDataType(attributeIndex) == DataType.NONE:
item.setDataType(attributeIndex, reply.valueType)
return self.client.updateValue(item, attributeIndex, reply.value)
what code i mention to update this in reader.py
8 months 2 weeks ago
Hi, At first, ensure you…
At first, ensure you have sufficient access rights to modify the value.
You can do it like this:
obj = GXDLMSData("0.0.94.96.19.255")
self.read(obj, 2)
obj.value = 1 + obj.value
self.write(obj, 2)
Check also this:
https://gurux.fi/Gurux.DLMS.Client
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
  • Mon, 04/13/2026 - 11:39
    Gurux.DLMS.Net 9.0.2604.1301
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
