  2. DLMS Connection Issue With SI Controller(EFR32xG23B)
DLMS connection issue with SI controller(EFR32xG23B)
By supritha, 25 July, 2025
when I am trying to communicate with the meter, I am facing issue at 7th transmission I am getting error code response from the meter as read write denied.
could you assist with this issue.
Regards
Supritha K P
8 months 1 week ago
Hi, I believe the object you…
I believe the object you try to read does not exist on the meter. Check that the logical name and object type are correct.
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • Tue, 04/07/2026 - 14:50
    gurux.dlms.java 4.0.91
  • Tue, 04/07/2026 - 14:00
    Gurux.DLMS.Net 9.0.2604.0701
  • Mon, 03/30/2026 - 15:39
    gurux.dlms.c 9.0.2603.3001
