  2. Svr_postWrite: Args->size Always Zero
svr_postWrite: args->size Always Zero
By andale8592, 16 July, 2025
Gurux DLMS for ANSI C
I'm currently developing using the example provided here:
https://github.com/Gurux/GuruxDLMS.c/tree/master/GuruxDLMSSimpleServerE…
I've noticed that in the svr_postWrite function, the args->size parameter is always zero. As a result, the loop inside that function never executes.
Here is the relevant source code:
https://github.com/Gurux/GuruxDLMS.c/blob/136207781359516d959ee0c3ebf26…
Could you please confirm if this is expected behavior or if there's something I might be missing?
Best regards,
Alessandro
9 months 4 weeks ago
Hi Alessandro, Have you…
Hi Alessandro,
Have you modified the source code? I just checked this and args->size was one as expected.
  • Wed, 05/13/2026 - 10:33
    gurux.dlms.cpp 9.0.2605.1301
  • Mon, 05/11/2026 - 11:07
    Gurux.DLMS.Go 1.0.17
  • Mon, 04/27/2026 - 08:37
    Gurux.DLMS.Go 1.0.16
  • Thu, 04/23/2026 - 13:19
    Gurux.DLMS.Net 9.0.2604.2101
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
