  2. DLMS Python Client : Unknown Object
DLMS python client : unknown object
By Harshi_554, 9 June, 2025
Hii,
I'm running DLMS python client code. Why the below prints appears on the screen? Does it cause error while saving the output to xml file?
Unknown object : 77 0.0.24.9.0.255
Unknown object : 76 0.0.24.8.0.255
Unknown object : 123 0.0.18.0.0.255
Unknown object : 151 0.0.25.11.0.255
9 months ago
Hi, M-Bus diagnostic, M-Bus…
M-Bus diagnostic, M-Bus port setup, array manager, and LTE monitoring are not implemented in Python because customers haven't requested them.
You can ignore this warning if you don't need those objects.
  • Thu, 02/19/2026 - 11:51
    gurux.dlms.cpp 9.0.2602.1901
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Gurux C library DLMS book edition support
  • Help with connection and read with landis+gyr e650 + CU-E22 using python
  • Preestablished connection
  • RJ11 to RS232 Pin out SECURE Premier 300
  • GENUS sugam 3 PH bidirectional
