  2. Scalar Value For Profile Data Values
Scalar value for profile data values
By L0uisc_iot, 5 March, 2025
Gurux.Net
Hi, I'm using the .net library to read a DLMS meter. When I read a load profile, the capture object's scalar property is 1, but the values obviously needs some scaling (0.01 in my case).
How can I get the correct scalar when reading the values from the load profile? Do I need to read the value's register separately and find its scalar first?
9 months ago
Hi, You are right. You need…
You are right. You need to read scaler from all registers or set it manually to to the register. After it's set, the scaler is used automatically with profile generic.
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • SNRM byte mening
