  2. Destination Address of Pushset Up
destination address of pushset up
By jayaram , 24 January, 2025
Gurux.Net
How to change destination address of pushset up using dlms .net library
1 year 4 months ago
Hi, Change the Send…
Change the Send destination and method value (attribute index #3).
https://gurux.fi/Gurux.DLMS.Objects.GXDLMSPushSetup
I believe the best way to go is if you use GXDLMSDirector first. It will help you to see the correct format that your meter is using.
