  2. Relay Connect VIA Python Code Using Gurux.DLMS.Client.Example.python
Relay Connect VIA Python Code using Gurux.DLMS.Client.Example.python
By Kumaresh, 10 December, 2024
Known problems
Hi, Kurmi ji
How I can connect the Smart meter relay via python code.
Am using Serial port HDLC to read the meters.
Pls give me way to resolve my issue or a sample Code to connect relay.
12 months ago
Hi, You can do it like this:…
dc = GXDLMSDisconnectControl("YOUR_LOGICAL_NAME")
#Disconnect.
data = dc.remoteDisconnect(self.client)
reply = GXReplyData()
#Reconnect.
data = dc.remoteReconnect(self.client)
Kumaresh
12 months ago
Hi, Kurumi ji, Thanks for…
Kurumi ji,
Thanks for the support.
Is it possible to update the image of the meter as I want to perform Firmware upgrade in the same way.....
11 months 4 weeks ago
Hi, Check Image updating…
Check Image updating from here:
https://gurux.fi/Gurux.DLMS.Client
  • Wed, 12/10/2025 - 08:45
    gurux.dlms.java 4.0.85
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • GXTIME Conversion Issue
  • DLMS Meter Gurux DLMS Director Properties
  • Using MAX3232 + FT232RL to Energy meter with GXDLMS Director
  • SNRM byte mening
