By shaaa , 29 April, 2024 Forums General discussion Hi, I am having an issue. When I put the COM port in source setting the program still cant read the data instead of just show same as not changing the COM port. Image Hi, Give the serial port… Hi, Give the serial port that you want to use as a parameter. Something like: -S COM1 BR, Mikko I use COM4 -S COM4 Is it… I use COM4 -S COM4 Is it correct that I change the com at source setting from the gurux library? Hi, COM1 was only an example… Hi, COM1 was only an example. You can use any serial port you want to. You can modify the example for your needs. BR, Mikko
-S COM1
I use COM4
-S COM4
