  2. Problems With Device Template
Problems with Device Template
By arobles , 17 November, 2023
Gurux.DLMS.AMI
How can I obtain the device template ami.gxc, as seen in the quick configuration guide:
https://www.youtube.com/watch?v=xm83-j0iDGg
Regads
2 years 6 months ago
Hi, You can create device…
You can create device template with GXDLMSDirector. Read your meter with GXDLMSDirector and then save it and add .gxc file to the AMI.
arobles
Hi Mr Kurumi, I have…
Hi Mr Kurumi,
I have simulated crystal meter data using Gurux.DLMS.Simulator.NET, I have saved the simulated meters as a template, but when importing the template in Gurux.DLMS.AMI I have this error:
Hi, You can't use a…
You can't use a simulator because the data structure is different. You need to use GXDLMSDirector template.
