  2. Value Keep Spamming and Error At Reader.getAssociationView()
Value keep spamming and error at reader.getAssociationView()
By Ansarr24 , 10 October, 2023
Known problems
Issue: Output keep spamming value.
Manufacturer: DZG
Input: python main.py -S COM4 -a Low -P 33333333 -s 255 -c 20 -g "0.0.1.0.0.255:1" -t Verbose -f 288
Info: [09:57:56.616] dlms obj IECAddress is 0000017F,Client id is 14,Password is33333333,Authentication is Low,Req_AP_Title is 0000000000000000
Error Log: Authentication: 1
ClientAddress: 0x14
ServerAddress: 0xff
Standard: 0
TX: 15:30:14 7E A0 15 02 FF 29 93 E5 48 81 80 08 05 02 01 20 06 02 01 20 C5 D7 7E
RX: 15:30:14 7E A0 21 29 02 FF 73 CC 61 81 80 14 05 02 01 20 06 02 01 20 07 04 00 00 00 01 08 04 00 00 00 01 0B C9 7E
TX: 15:30:14 7E A0 45 02 FF 29 10 14 8B E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 33 33 33 33 33 33 33 33 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF A3
A9 7E
RX: 15:30:15 7E A0 38 29 02 FF 30 77 F4 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 01 20 00 07 76 D3 7E
TX: 15:30:15 7E A0 1A 02 FF 29 32 9A 96 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
RX: 15:30:15 7E A1 39 29 02 FF 52 0C BB E6 E7 00 C4 02 C1 00 00 00 00 01 00 82 01 20 01 82 2A 4C 02 04 12 00 0F 11 01 09 06 00 00 28 00 01 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 02 03 0F 03 16 01 00 02
03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 00 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 00 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 02 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 02 00 02 03 0F 08 16 01 00 02 03 0F 09 16 00 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 03 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 02 00 02 03 0F 08 16 01 00 02 03 0F 09 16 00 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28
00 04 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 00 B2 6D 7E
TX: 15:30:15 7E A0 14 02 FF 29 54 12 F1 E6 E6 00 C0 02 C1 00 00 00 01 51 BE 7E
RX: 15:30:16 7E A1 39 29 02 FF 74 38 FF E6 E7 00 C4 02 C1 00 00 00 00 02 00 82 01 20 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 02 00 02 03 0F 08 16 01 00 02 03
0F 09 16 00 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 05 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 02 00 02 03 0F 08 16 01 00 02 03 0F 09 16 00 00 01 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 06 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 01 00 02 03 0F 09 16 00 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 09
01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 D6 C2 7E
TX: 15:30:16 7E A0 14 02 FF 29 76 02 F3 E6 E6 00 C0 02 C1 00 00 00 02 CA 8C 7E
File "C:\Users\SMT\Documents\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python\main.py", line 102, in main
File "C:\Users\SMT\Documents\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python\GXDLMSReader.py", line 518, in getAssociationView
self.readDataBlock(self.client.getObjectsRequest(), reply)
File "C:\Users\SMT\Documents\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python\GXDLMSReader.py", line 188, in readDataBlock
File "C:\Users\SMT\Documents\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python\GXDLMSReader.py", line 118, in readDLMSPacket
File "C:\Users\SMT\Documents\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python\GXDLMSReader.py", line 159, in readDLMSPacket2
while not self.media.receive(p):
File "C:\Users\SMT\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_serial\GXSerial.py", line 389, in receive
return self.__syncBase.receive(args)
File "C:\Users\SMT\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_serial\_GXSynchronousMediaBase.py", line 244, in receive
foundPosition = self.__findData(args)
File "C:\Users\SMT\AppData\Local\Programs\Python\Python311\Lib\site-packages\gurux_serial\_GXSynchronousMediaBase.py", line 193, in __findData
isReceived = self.__receivedEvent.wait(waitTime / 1000)
File "C:\Users\SMT\AppData\Local\Programs\Python\Python311\Lib\threading.py", line 622, in wait
signaled = self._cond.wait(timeout)
File "C:\Users\SMT\AppData\Local\Programs\Python\Python311\Lib\threading.py", line 324, in wait
gotit = waiter.acquire(True, timeout)
KeyboardInterrupt
2 years 8 months ago
Hi, You try to read the…
You try to read the association view and it's not a complete read.
When you try to read data block #2 the meter doesn't return it.
If this happens every time at the same location you need to ask the meter vendor if there is a firmware update available for the meter that fixes this issue
Ansarr24
New update.. if i wait until…
New update.. if i wait until it finish spamming output, the value will appear. The process take up to 5 minutes. It is normal or is there a way to speed up the process? Thank you for your response. :)
Hi, If you add -o file.xml…
If you add -o file.xml the association view is saved to the file. It will save some time.
Now you are reading all the objects from the meter and there might be hundreds of objects.
Try to add
-g 0.0.1.0.0.255:2
It will read only the current time from the meter.
