  2. DLMS Over LoraWan In Water Metering
DLMS over LoraWan in water metering
By labasvakaras, 15 July, 2025
Hello, wanted to ask a question, maybe you will have some insights.
We are trying to find a solution to launch DLMS over Lorawan. One thing is that our product is battery-powered water meter.
I have questions:
1. Maybe you have real life examples that this was done before?
2. time / Duty cycle - this time is very strict in lorawan, how it is possible to overcome this barrier when DLMS handshake takes up to 6-12 telegrams?
8 months 2 weeks ago
Hi, I believe that the best…
I believe that the best way to do this is if the meter uses push messages.
https://gurux.fi/Gurux.DLMS.Objects.GXDLMSPushSetup
DLMS and LoRa are not an easy combination.
labasvakaras
if i am using push setup and…
if i am using push setup and push messages, do I need to establish communication with AARQ/AARE messages?
Hi, AARQ/AARE are not used…
AARQ/AARE are not used with Push messages. The meter sends only the data, and a connection to the meter is not established.
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • Tue, 04/07/2026 - 14:50
    gurux.dlms.java 4.0.91
  • Tue, 04/07/2026 - 14:00
    Gurux.DLMS.Net 9.0.2604.0701
  • Mon, 03/30/2026 - 15:39
    gurux.dlms.c 9.0.2603.3001
