  2. The Date Is Not Displayed Correctly.
The date is not displayed correctly.
By benyamin.chesh…, 14 April, 2025
Hello
I am facing this problem in getting the date. I would be grateful if you could suggest me a solution.
The time is correct, but the date is wrong, and the correct date is glorious
trace debug
Clock : Index: 2 Value: 01/01/1970 18:10:47<LF>
Index: 3 Value: -210<LF>
Index: 4 Value: 0<LF>
Index: 5 Value: 01/01/1970 00:00:00 UTC+00:00<LF>
Index: 6 Value: 01/01/1970 00:00:00 UTC+00:00<LF>
Index: 7 Value: 0<LF>
Index: 8 Value: 0<LF>
Index: 9 Value: 0<LF>
<CR><LF>
7E A0 2F 00 02 26 69 03 DC 8D F9 E6 E6 00 C8 1E 30 00 00 1B D4 6F 72 AA 26 E4 F7 FD 9A 4B E4 05 78 0D 15 B6 6F 88 EC 57 3D 2C 09 52 B4 67 00 73 7E 7E A0 29 03 00 02 26 69 FC 9C B3 E6 E7 00 CC 18 30 00 00 02 72 F2 D3 3C 10 A1 6E FB CC A5 DC 13 F6 59 08 73 E6 8D 72 9E C6 D4 7E 7E A0 2F 00 02 26 69 03 FE 9D FB E6 E6 00 C8 1E 30 00 00 1B D5 D7 73 8B 32 91 06 28 2F 20 B1 F2 41 AA C8 BF BD DC 67 9F 14 50 E4 DF 1F BF B3 69 7E 7E A0 34 03 00 02 26 69 1E 06 EC E6 E7 00 CC 23 30 00 00 02 73 E5 A8 4C E4 11 1B 2A 3F 97 E3 A5 8B 3D 77 9B B0 70 77 78 04 95 45 F5 9A AD 26 9A E2 C7 72 70 C9 7E
benyamin.chesh…
10 months ago
GuruxDLMS.c/Arduino_IDE…
GuruxDLMS.c/Arduino_IDE/client
/client.ino
I am developing in this environment.
benyamin.chesh…
10 months ago
I tried again with this…
I tried again with this program.
my code:
gxClock clock1;
int ret_Func ;
char* data = NULL;
cosem_init(BASE(clock1), DLMS_OBJECT_TYPE_CLOCK, logicalNameString);
com_read(BASE(clock1), 9);
com_read(BASE(clock1), 8);
com_read(BASE(clock1), 7);
com_read(BASE(clock1), 6);
com_read(BASE(clock1), 5);
com_read(BASE(clock1), 4);
com_read(BASE(clock1), 3);
com_read(BASE(clock1), 2);
obj_toString(BASE(clock1), &data);
printf("Clock : %s \r\n", data);
obj_clear(BASE(clock1));
free(data);
tace debug:
Index: 2 Value: 01/01/1970 18:34:53<LF>
Index: 4 Value: 128<LF>
Index: 7 Value: 60<LF>
Index: 8 Value: 1<LF>
Index: 9 Value: 1<LF>
<CR><LF>
7E A0 2F 00 02 26 69 03 DC 8D F9 E6 E6 00 C8 1E 30 00 00 1C 27 5F D9 F0 D8 7C 50 FD 5D 4F 27 12 A6 05 94 3D 6D F1 18 02 92 3C 36 53 1A 70 01 4B 7E 7E A0 28 03 00 02 26 69 FC 49 2C E6 E7 00 CC 17 30 00 00 02 C0 D9 38 64 3B 54 F9 17 C2 68 43 8F 91 97 54 4E 48 32 86 C1 5D 7E 7E A0 2F 00 02 26 69 03 FE 9D FB E6 E6 00 C8 1E 30 00 00 1C 28 9A 9B 46 26 B8 F7 33 92 D0 DA 15 C0 AC 29 EC 0E F2 C9 B7 63 0B E7 8F 96 41 D1 F5 7E 7E A0 28 03 00 02 26 69 1E 55 E8 E6 E7 00 CC 17 30 00 00 02 C1 90 58 9D 6E BE 58 6C 53 57 28 1F 9C 85 5C FC 2B 05 7D BF 75 7E 7E A0 2F 00 02 26 69 03 10 ED F5 E6 E6 00 C8 1E 30 00 00 1C 29 EE A3 B0 87 DA CD C9 B4 B1 C3 90 C2 ED E7 2B F0 0E 81 51 91 B3 6B B5 80 5B A4 47 7E 7E A0 28 03 00 02 26 69 30 29 20 E6 E7 00 CC 17 30 00 00 02 C2 B3 D3 99 FD 92 3F C7 C1 AE 90 69 3C 45 A6 FE 5C 7B D8 50 F3 7E 7E A0 2F 00 02 26 69 03 32 FD F7 E6 E6 00 C8 1E 30 00 00 1C 2A 27 9E E9 E9 34 39 6B 01 A4 C2 D1 E2 54 59 FD 7B CA D3 A4 3C A3 CA FF 9D 5E 58 71 7E 7E A0 27 03 00 02 26 69 52 C9 79 E6 E7 00 CC 16 30 00 00 02 C3 26 63 C7 0D B3 14 A4 F2 89 CF 4F 5C 26 7D E0 C9 4C C4 25 7E 7E A0 2F 00 02 26 69 03 54 CD F1 E6 E6 00 C8 1E 30 00 00 1C 2B 04 E3 E3 39 0A 59 B0 25 6F 0D 97 27 30 74 94 3B F4 6F 4D 7C F0 6E 01 2A 77 3A 7B 7E 7E A0 27 03 00 02 26 69 74 FD 3D E6 E7 00 CC 16 30 00 00 02 C4 49 91 84 81 AD 60 97 DD 0D F7 FA 80 64 B3 E2 77 30 C3 E3 7E 7E A0 2F 00 02 26 69 03 76 DD F3 E6 E6 00 C8 1E 30 00 00 1C 2C 94 51 D7 35 46 7D D4 53 3B 77 62 27 7B E4 5F 2C 4D 06 45 AF EB EA 7C B9 AC 21 26 7E 7E A0 28 03 00 02 26 69 96 15 E0 E6 E7 00 CC 17 30 00 00 02 C5 13 9E 4E 31 E3 91 85 46 42 89 12 42 B4 9B B9 AC 3F 6E AE 3C 7E 7E A0 2F 00 02 26 69 03 98 AD FD E6 E6 00 C8 1E 30 00 00 1C 2D D5 BF CC B9 C0 47 C8 C5 10 DE 53 3B E9 81 8B 8E DF 90 47 A8 01 01 6A 04 0A 99 4D 7E 7E A0 29 03 00 02 26 69 B8 BC B7 E6 E7 00 CC 18 30 00 00 02 C6 F8 26 4D 67 1C 94 56 26 0F 94 F1 4B 7A F0 28 84 5B BA 1F BF D3 7E 7E A0 2F 00 02 26 69 03 BA BD FF E6 E6 00 C8 1E 30 00 00 1C 2E C6 C5 C2 F0 D3 28 B9 38 E3 17 3E 24 9B F1 12 51 E2 E7 9D 4F E0 BE 67 D3 81 A7 D6 7E 7E A0 34 03 00 02 26 69 DA 2E 6C E6 E7 00 CC 23 30 00 00 02 C7 55 F5 D7 C2 2A 0A 73 60 06 14 FE B4 50 E7 AA 28 46 E3 CB 74 1E F5 1A 07 2F B2 8F 38 8B F7 3F 94 7E
10 months ago
Hi, The PDU is ciphered. I…
The PDU is ciphered. I need the block cipher key to solve this.
benyamin.chesh…
10 months ago
Hello, with respect. bb…
bb_addHexString(&bb, GET_STR_FROM_EEPROM("00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F"));
SetBlockCipherKey(&bb);
10 months ago
Hi, Are you reading the…
Are you reading the example meter? You haven't set the year, month, or day to the meter, and time starts from 1970.
benyamin.chesh…
10 months ago
No, I am reading information…
No, I am reading information from a real meter
It reads the time and date correctly with the software GXDLMSDirector, but when I read it with Arduino, it cannot read the date
I am confused where to set the date
benyamin.chesh…
10 months ago
trace with software wit…
I read the same meter with the software
20:03:46 Read object type Clock index: 2
TX: 7E A0 2F 00 02 26 69 03 54 CD F1 E6 E6 00 C8 1E 30 00 00 1C AC A5 14 E3 21 8B 33 A0 0F 7E 68 D6 D7 DE 5F D6 06 09 67 9F 99 67 58 B0 1A 96 66 4F 7E
20:03:46 08:03:46.955 Sent 7E A0 2F 00 02 26 69 03 54 CD F1 E6 E6 00 C8 1E 30 00 00 1C AC A5 14 E3 21 8B 33 A0 0F 7E 68 D6 D7 DE 5F D6 06 09 67 9F 99 67 58 B0 1A 96 66 4F 7E
20:03:47 08:03:47.095 Received 7E A0 34 03 00 02 26 69 74 5A 20 E6 E7 00 CC 23 30 00 00 01 1E 12 1A 3C 36 90 76 3B BE 3E 7F 8F
20:03:47 08:03:47.111 Received 8F F2 7F 93 FE 09 35 A4 28 F3 14 C9 6A 2B 64 DB 58 30 73 25 F7 33
20:03:47
RX: 7E A0 34 03 00 02 26 69 74 5A 20 E6 E7 00 CC 23 30 00 00 01 1E 12 1A 3C 36 90 76 3B BE 3E 7F 8F F2 7F 93 FE 09 35 A4 28 F3 14 C9 6A 2B 64 DB 58 30 73 25 F7 33 7E
20:03:47 Read object type Clock index: 8
TX: 7E A0 2F 00 02 26 69 03 76 DD F3 E6 E6 00 C8 1E 30 00 00 1C AD 49 FF DD 9E DD D2 09 04 A0 FE 02 CB D2 34 E2 B8 EE 3F 12 0F 04 4E BA 1A 59 95 31 7E
20:03:47 08:03:47.142 Sent 7E A0 2F 00 02 26 69 03 76 DD F3 E6 E6 00 C8 1E 30 00 00 1C AD 49 FF DD 9E DD D2 09 04 A0 FE 02 CB D2 34 E2 B8 EE 3F 12 0F 04 4E BA 1A 59 95 31 7E
20:03:47 08:03:47.267 Received 7E A0 28 03 00 02 26 69 96 15 E0 E6 E7 00 CC 17 30 00 00 01 1F 50 0C BB 04 F6 56 E8 55 62 7B 70
20:03:47 08:03:47.283 Received 70 67 EE 47 61 1B FD FB 7B 69
20:03:47
RX: 7E A0 28 03 00 02 26 69 96 15 E0 E6 E7 00 CC 17 30 00 00 01 1F 50 0C BB 04 F6 56 E8 55 62 7B 70 67 EE 47 61 1B FD FB 7B 69 7E
10 months ago
Hi, Can you add the hex log…
Can you add the hex log from AARQ and AARE messages?
Those messages are generated when you establish the connection to the meter.
benyamin.chesh…
10 months ago
trace with aduino ----------…
trace with aduino
4/15/2025 11:58:45.234 [RX] - 7E A0 0A 00 02 26 69 21 93 DD C0 7E 7E A0 23 21 00 02 26 69 73 02 AB 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00 00 01 69 6D 7E 7E A0 2E 00 02 26 69 21 10 BB 7A E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 7E A0 3A 21 00 02 26 69 30 6D 2F E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10 05 00 00 07 8D FF 7E 7E A0 1C 00 02 26 69 21 32 5A 99 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 00 FF 02 00 7D 8F 7E 7E A0 18 21 00 02 26 69 52 41 3B E6 E7 00 C4 01 C1 00 06 00 00 1C C1 C9 F3 7E 7E A0 0A 00 02 26 69 21 53 D1 06 7E 7E A0 0A 21 00 02 26 69 73 B8 89 7E 7E A0 0A 00 02 26 69 03 93 5E D0 7E 7E A0 23 03 00 02 26 69 73 34 26 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00 00 01 69 6D 7E 7E A0 6E 00 02 26 69 03 10 3E AD E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 00 00 1C C2 30 71 A1 FF 6E 72 ED F9 70 93 33 DA A3 B8 9E C1 8D 15 DA 68 53 8B 1B 36 2B C8 EB 69 7E 7E A0 72 03 00 02 26 69 30 B1 BB E6 E7 00 61 61 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 45 41 41 07 00 22 5A DC 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 0A 80 08 6C D6 75 1B D2 50 99 1F BE 23 04 21 28 1F 30 00 00 01 F4 C1 34 EC DF 5A 9C CB 44 B1 BF 9A E5 3A DD 26 CD E5 9A BC 38 32 6A B0 88 BB 07 34 A4 7E 7E A0 42 00 02 26 69 03 32 37 7D E6 E6 00 CB 31 30 00 00 1C C3 5E A7 1A A1 2D ED BF 20 DD D1 C9 FC 77 09 B0 A8 76 AD F8 40 5C 37 4F AA 14 A7 17 06 37 A3 C3 E8 A3 8C 77 EA 53 47 05 A2 EC 88 FE 08 D9 EE 7E 7E A0 3B 03 00 02 26 69 52 9A 7D E6 E7 00 CF 2A 30 00 00 01 F5 2E 66 BD 5C 9A 86 BD ED B3 01 C2 BC 7A 98 44 97 E4 B0 CE 25 86 58 5B DE D5 44 A0 4F 38 4B 70 CF 78 16 57 DC CD 73 CA 7E 7E A0 2F 00 02 26 69 03 54 CD F1 E6 E6 00 C8 1E 30 00 00 1C C4 35 E9 20 15 E8 A7 68 B4 A7 43 BC A1 12 FB CF 91 17 5B 45 2E C6 1F 76 6A DE 4C 37 7E 7E A0 28 03 00 02 26 69 74 09 24 E6 E7 00 CC 17 30 00 00 01 F6 77 9A F5 0C 94 12 CB D4 BB 0E 7F 8A 1C B4 C7 58 3C 75 AF 97 7E 7E A0 2F 00 02 26 69 03 76 DD F3 E6 E6 00 C8 1E 30 00 00 1C C5 E8 21 70 87 04 F5 4B 7B A7 BC AB E0 76 08 A1 9E 25 71 DA 20 94 BF 90 6C D3 9D D9 7E 7E A0 28 03 00 02 26 69 96 15 E0 E6 E7 00 CC 17 30 00 00 01 F7 E3 A7 80 6B 9C 78 3A 23 F4 CA B7 7A 2E 1A 25 EB 2E 9B 87 70 7E 7E A0 2F 00 02 26 69 03 98 AD FD E6 E6 00 C8 1E 30 00 00 1C C6 EA 0C FB E4 A0 0C 4B 04 2D B7 A7 79 4D 5B 4A E8 EE 76 A8 0B C3 F9 A0 56 5E 25 06 7E 7E A0 28 03 00 02 26 69 B8 69 28 E6 E7 00 CC 17 30 00 00 01 F8 00 48 0E E5 E2 A1 A8 62 43 AF 18 37 5C A0 ED 13 21 0D 6F DB 7E 7E A0 2F 00 02 26 69 03 BA BD FF E6 E6 00 C8 1E 30 00 00 1C C7 20 B8 AC 5A 71 38 90 87 C6 F2 25 C1 96 2C 9C 6C 2A A1 33 EC 0D F2 31 B6 E3 86 05 7E 7E A0 27 03 00 02 26 69 DA 89 71 E6 E7 00 CC 16 30 00 00 01 F9 F2 72 50 35 EC B1 68 72 D9 E1 B0 52 4F A2 51 34 FA 6C 37 7E 7E A0 2F 00 02 26 69 03 DC 8D F9 E6 E6 00 C8 1E 30 00 00 1C C8 4C 07 91 8C 98 0B CA 52 3D EE 0F B9 E3 E2 BD 84 38 A3 03 F5 86 58 CD 44 41 FB E1 7E 7E A0 27 03 00 02 26 69 FC BD 35 E6 E7 00 CC 16 30 00 00 01 FA A8 9E 5F 99 46 C5 93 0B DD 1F 41 C2 9F 9D 20 D7 42 12 5D 7E 7E A0 2F 00 02 26 69 03 FE 9D FB E6 E6 00 C8 1E 30 00 00 1C C9 D8 21 06 09 B0 67 39 3A 21 6C D4 0C 97 65 32 64 ED 42 7E AE 58 DA EE 47 18 C1 E0 7E 7E A0 28 03 00 02 26 69 1E 55 E8 E6 E7 00 CC 17 30 00 00 01 FB FA 58 E8 00 3E 74 D3 F3 A8 B1 C1 28 1B 83 C7 DD AD A2 03 09 7E 7E A0 2F 00 02 26 69 03 10 ED F5 E6 E6 00 C8 1E 30 00 00 1C CA 58 96 F9 F7 A3 B5 79 23 DA 34 95 55 CE CB 8C 1B F0 2A E7 91 77 8F 52 0D 14 19 4E 7E 7E A0 29 03 00 02 26 69 30 FC BF E6 E7 00 CC 18 30 00 00 01 FC D9 71 13 40 39 8C 9B 23 55 1B 9B 55 95 F2 E6 18 FE 9B E9 13 04 7E 7E A0 2F 00 02 26 69 03 32 FD F7 E6 E6 00 C8 1E 30 00 00 1C CB 7A CD 1F DC CE D2 79 C6 D3 48 7D 5A 6C C7 A2 78 23 03 49 8E B1 CA 9E 70 33 E4 77 7E 7E A0 34 03 00 02 26 69 52 6E 64 E6 E7 00 CC 23 30 00 00 01 FD 9B 1F 63 3D 13 BF A6 34 2C D0 5B D5 67 C9 9D AB 5B 56 50 51 1F 16 08 40 0B D4 63 4F B0 45 BD 49 7E
**************Invocation Counter: 7361 , hex( 1cc1 )<LF>
com_initializeConnection SUCCEEDED 0 <LF>
com_read failed.3com_read failed.3Clock : Index: 2 Value: 01/01/1970 12:57:29<LF>
<CR><LF>
benyamin.chesh…
10 months ago
trace with sotware…
trace with sotware gxdlmsdirector
11:51:52 11:51:52.063 Info Opening
11:51:52 11:51:52.063 Info Serial Port Settings: Port Name: COM16 Baud Rate: 9600 Data Bits: 8 Parity: None Stop Bits: One Flow Control: None Eop: None
11:51:52 11:51:52.078 Info Open
11:51:53 Send SNRM request.
TX: 7E A0 0A 00 02 26 69 21 93 DD C0 7E
11:51:53 11:51:53.094 Sent 7E A0 0A 00 02 26 69 21 93 DD C0 7E
11:51:53 11:51:53.140 Received 7E A0 23 21 00 02 26 69 73 02 AB 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00
11:51:53 11:51:53.140 Received 00 00 01 69 6D
11:51:53
RX: 7E A0 23 21 00 02 26 69 73 02 AB 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00 00 01 69 6D 7E
11:51:53 Send AARQ request.
TX: 7E A0 2E 00 02 26 69 21 10 BB 7A E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
11:51:53 11:51:53.140 Sent 7E A0 2E 00 02 26 69 21 10 BB 7A E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
11:51:53 11:51:53.234 Received 7E A0 3A 21 00 02 26 69 30 6D 2F E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00
11:51:53 11:51:53.265 Received 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10 05 00 00 07 8D FF
11:51:53
RX: 7E A0 3A 21 00 02 26 69 30 6D 2F E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10 05 00 00 07 8D FF 7E
11:51:53 11:51:53.265 Sent 7E A0 1C 00 02 26 69 21 32 5A 99 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 00 FF 02 00 7D 8F 7E
11:51:53 11:51:53.328 Received 7E A0 18 21 00 02 26 69 52 41 3B E6 E7 00 C4 01 C1 00 06 00 00 1C B3 5C A3 7E
11:51:53
RX: 7E A0 18 21 00 02 26 69 52 41 3B E6 E7 00 C4 01 C1 00 06 00 00 1C B3 5C A3 7E
11:51:53 Disconnect request
TX: 7E A0 0A 00 02 26 69 21 53 D1 06 7E
11:51:53 11:51:53.328 Sent 7E A0 0A 00 02 26 69 21 53 D1 06 7E
11:51:53 11:51:53.359 Received 7E A0 0A 21 00 02 26 69 73 B8 89 7E
11:51:53
RX: 7E A0 0A 21 00 02 26 69 73 B8 89 7E
TX: 7E A0 0A 00 02 26 69 03 93 5E D0 7E
11:51:53 11:51:53.359 Sent 7E A0 0A 00 02 26 69 03 93 5E D0 7E
11:51:53 11:51:53.406 Received 7E A0 23 03 00 02 26 69 73 34 26 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00
11:51:53 11:51:53.406 Received 00 00 01 69 6D
11:51:53
RX: 7E A0 23 03 00 02 26 69 73 34 26 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00 00 01 69 6D 7E
TX: 7E A0 6E 00 02 26 69 03 10 3E AD E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 59 46 5F 42 30 4D 46 61 5C 5D 6F 03 51 1F 71 39 BE 23 04 21 21 1F 30 00 00 1C B4 12 F7 94 44 77 0B 89 2F C8 C0 9C 8E 2B BC 10 20 AB 82 98 6B E8 63 25 A9 DD 48 7F 89 7E
11:51:53 11:51:53.406 Sent 7E A0 6E 00 02 26 69 03 10 3E AD E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 59 46 5F 42 30 4D 46 61 5C 5D 6F 03 51 1F 71 39 BE 23 04 21 21 1F 30 00 00 1C B4 12 F7 94 44 77 0B 89 2F C8 C0 9C 8E 2B BC 10 20 AB 82 98 6B E8 63 25 A9 DD 48 7F 89 7E
11:51:53 11:51:53.609 Received 7E A0 72 03 00 02 26 69 30 B1 BB E6 E7 00 61 61 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00
11:51:53 11:51:53.640 Received 00
11:51:53 11:51:53.672 Received 05 AA 0A 80 08 3B BB E9 67 EE 46 26 30 BE 23 04 21 28 1F 30 00 00 01 E8 08 BC 68 07 94 1D 12 9B
11:51:53 11:51:53.703 Received 80 B4 43 FC E9 0E 3D 2C 0E C2 9A 87 DE 7F 49 7F 17 D6 85 DF
11:51:53
RX: 7E A0 72 03 00 02 26 69 30 B1 BB E6 E7 00 61 61 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 45 41 41 07 00 22 5A DC 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 0A 80 08 3B BB E9 67 EE 46 26 30 BE 23 04 21 28 1F 30 00 00 01 E8 08 BC 68 07 94 1D 12 9B 80 B4 43 FC E9 0E 3D 2C 0E C2 9A 87 DE 7F 49 7F 17 D6 85 DF 7E
11:51:53 Authenticating.
TX: 7E A0 42 00 02 26 69 03 32 37 7D E6 E6 00 CB 31 30 00 00 1C B5 2A 88 FC E6 2B 47 D8 94 20 D8 2D 4C 1D 84 D4 60 20 F9 6A 1E 76 7F 39 FE 30 EA FF C8 92 26 5F 5E E6 8A B0 DD 32 B2 7F E7 D0 26 45 AF AF 06 7E
11:51:53 11:51:53.703 Sent 7E A0 42 00 02 26 69 03 32 37 7D E6 E6 00 CB 31 30 00 00 1C B5 2A 88 FC E6 2B 47 D8 94 20 D8 2D 4C 1D 84 D4 60 20 F9 6A 1E 76 7F 39 FE 30 EA FF C8 92 26 5F 5E E6 8A B0 DD 32 B2 7F E7 D0 26 45 AF AF 06 7E
11:51:53 11:51:53.890 Received 7E A0 3B 03 00 02 26 69 52 9A 7D E6 E7 00 CF 2A 30 00 00 01 E9 12 A5 F7 6B 99 3E 59 34 D2 01 D2
11:51:53 11:51:53.921 Received D2 2A 81 36 4F 2C 5D 23 E5 BA E2 CE E3 34 62 38 4B D6 81 CD 7F 90 5D CB 8D 6E C1 E4 47
11:51:53
RX: 7E A0 3B 03 00 02 26 69 52 9A 7D E6 E7 00 CF 2A 30 00 00 01 E9 12 A5 F7 6B 99 3E 59 34 D2 01 D2 2A 81 36 4F 2C 5D 23 E5 BA E2 CE E3 34 62 38 4B D6 81 CD 7F 90 5D CB 8D 6E C1 E4 47 7E
11:52:07 Read object type Clock index: 2
TX: 7E A0 2F 00 02 26 69 03 54 CD F1 E6 E6 00 C8 1E 30 00 00 1C B6 36 B8 77 28 02 DB C2 57 D5 F5 04 40 BB 76 7F 3C 37 21 25 5F 94 E1 4F 62 DA F5 54 7E
11:52:07 11:52:07.043 Sent 7E A0 2F 00 02 26 69 03 54 CD F1 E6 E6 00 C8 1E 30 00 00 1C B6 36 B8 77 28 02 DB C2 57 D5 F5 04 40 BB 76 7F 3C 37 21 25 5F 94 E1 4F 62 DA F5 54 7E
11:52:07 11:52:07.184 Received 7E A0 34 03 00 02 26 69 74 5A 20 E6 E7 00 CC 23 30 00 00 01 EA AC 91 B2 F1 F0 45 0B 20 73 F2 7B
11:52:07 11:52:07.200 Received 7B E9 1D B8 47 E9 41 93 51 D8 12 3E 83 AE CA 39 C0 9E 49 2A 01 6D
11:52:07
RX: 7E A0 34 03 00 02 26 69 74 5A 20 E6 E7 00 CC 23 30 00 00 01 EA AC 91 B2 F1 F0 45 0B 20 73 F2 7B E9 1D B8 47 E9 41 93 51 D8 12 3E 83 AE CA 39 C0 9E 49 2A 01 6D 7E
11:52:07 Read object type Clock index: 8
TX: 7E A0 2F 00 02 26 69 03 76 DD F3 E6 E6 00 C8 1E 30 00 00 1C B7 B6 3E 80 C9 33 2C 89 52 57 D5 29 05 50 01 E5 61 8F FD 1A 5C 19 A2 85 B4 73 1A 6F 7E
11:52:07 11:52:07.215 Sent 7E A0 2F 00 02 26 69 03 76 DD F3 E6 E6 00 C8 1E 30 00 00 1C B7 B6 3E 80 C9 33 2C 89 52 57 D5 29 05 50 01 E5 61 8F FD 1A 5C 19 A2 85 B4 73 1A 6F 7E
11:52:07 11:52:07.340 Received 7E A0 28 03 00 02 26 69 96 15 E0 E6 E7 00 CC 17 30 00 00 01 EB 67 41 0F 7D 4B 33 62 3D 3E 07 CD
11:52:07 11:52:07.356 Received CD 0B BC CD 09 0E 54 3A 6C DA
11:52:07
RX: 7E A0 28 03 00 02 26 69 96 15 E0 E6 E7 00 CC 17 30 00 00 01 EB 67 41 0F 7D 4B 33 62 3D 3E 07 CD 0B BC CD 09 0E 54 3A 6C DA 7E
10 months ago
Hi, Now I know the problem…
Now I know the problem. Hijri year is AH 1446. The Arduino client uses EPOCH time that starts from 1/1/1970.
Select ArduinoIgnore.h and comment this line:
#define DLMS_USE_EPOCH_TIME
benyamin.chesh…
10 months ago
Thank you for your guidance
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Python GXDLMSTranslator
  • Issue with KWH Value Reading Using Gurux DLMS Library.
  • CEWE Prometer 100
