  2. DLMS Simulator Not Working For WRAPPER Format
DLMS simulator not working for WRAPPER format
Profile picture for user sujit
By sujit , 19 August, 2024
We are facing issues while implementing the TCP wrapper for the simulation, but it is working fine for HDLC.
1 year 10 months ago
Hi, Did you start the…
Did you start the simulator with -WRAPPER argument?
sujit
Thank you !!!
Thank you !!!
sujit
1 year 9 months ago
Hii We are doing connection…
Hii
We are doing connection with US association i am attaching the screen shot below please help me to solve the issue
We are getting invalid client address error also I am attaching the command please let me know the correct version of it
also if i am adding -c 48 still i am getting invalid address
java -jar target/gurux.dlms.simulator.java-0.0.1-SNAPSHOT.jar -w -a High -C AuthenticationEncryption -T 4775727578313233 -A D0D1D2D3D4D5D6D7D8D9DA
DBDCDDDEDF -B 000102030405060708090A0B0C0D0E0F -D 00112233445566778899AABBCCDDEEFF -p 1000 -x crystal.xml -t Verbose -N 1
1 year 9 months ago
Hi, This template doesn't…
This template doesn't support GMAC authentication or ciphered connections. You need to import a template from the meter that supports ciphered connections.
sujit
1 year 9 months ago
Thank you for the replay,…
Could you please guide me on how to generate a template from the meter? If there is a specific command available for this process, I would appreciate it if you could share it with me.
1 year 9 months ago
Hi, Establish the connection…
Establish the connection to the meter you want to read using the settings that you want to use. The simulator will generate the template for you.
Check this:
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Simulato…
sujit
1 year 9 months ago
hii We are making the xml…
hii
We are making the xml file from meter after some req and res we are getting this error
plz help us to resolve this issue
java.lang.ArrayIndexOutOfBoundsException: Index 255 out of bounds for length 8
TX: 10:19:00.888 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 E9 5D 55 9D 1F 96 2D ED 25 2A F5 2A 62 85 3D AA 08 B5 C8 00 76 C0 F0 68 3E DA
TX: 10:20:00.898 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 E9 5D 55 9D 1F 96 2D ED 25 2A F5 2A 62 85 3D AA 08 B5 C8 00 76 C0 F0 68 3E DA
TX: 10:21:00.908 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 E9 5D 55 9D 1F 96 2D ED 25 2A F5 2A 62 85 3D AA 08 B5 C8 00 76 C0 F0 68 3E DA
TX: 10:22:00.923 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 E9 5D 55 9D 1F 96 2D ED 25 2A F5 2A 62 85 3D AA 08 B5 C8 00 76 C0 F0 68 3E DA
Error! Index: 7 Failed to receive reply from the device in given time.
java.lang.RuntimeException: Failed to receive reply from the device in given time.
-------- Reading GXDLMSData 0.0.94.91.0.255 Cumulative Tamper Count
TX: 10:23:00.942 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 EA 90 D0 D0 03 1B B0 C4 08 86 EF 5E C8 AF 3C 68 85 8E 10 C9 DC 03 FD 61 CD A6
TX: 10:24:00.957 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 EA 90 D0 D0 03 1B B0 C4 08 86 EF 5E C8 AF 3C 68 85 8E 10 C9 DC 03 FD 61 CD A6
TX: 10:25:00.965 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 EA 90 D0 D0 03 1B B0 C4 08 86 EF 5E C8 AF 3C 68 85 8E 10 C9 DC 03 FD 61 CD A6
TX: 10:26:00.972 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 EA 90 D0 D0 03 1B B0 C4 08 86 EF 5E C8 AF 3C 68 85 8E 10 C9 DC 03 FD 61 CD A6
Error! Index: 2 Failed to receive reply from the device in given time.
-------- Reading GXDLMSData 0.0.94.91.9.255 Meter Type
TX: 10:27:00.985 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 EB A4 CE D5 9C 77 BF 82 79 BD 7B FD F5 3E 31 4B A2 88 2B 9C AD 00 63 BD 66 1E
TX: 10:28:00.994 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 EB A4 CE D5 9C 77 BF 82 79 BD 7B FD F5 3E 31 4B A2 88 2B 9C AD 00 63 BD 66 1E
TX: 10:29:01.000 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 EB A4 CE D5 9C 77 BF 82 79 BD 7B FD F5 3E 31 4B A2 88 2B 9C AD 00 63 BD 66 1E
1 year 9 months ago
Hi, You are using the…
You are using the ciphered connection. I believe your block cipher or authentication key is different on the server and client sides.
sujit
1 year 9 months ago
No both keys are same Till…
Till image activation info its working after that we are getting this
Error! Index: 6 Index 255 out of bounds for length 8
Hii as of now I dont want to use Image activation info In developer folder I have commented the files which are related to image transfer still I am getting
Please help us to remove this issue
-------- Reading GXDLMSImageTransfer 0.0.44.0.0.255 Image Activation Info
TX: 10:18:53.656 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 E4 F5 FC B1 AE 39 51 1B EA A1 52 F5 0F 08 6D 1E 80 11 16 6E 92 6E F6 7A 50 D2
RX: 10:18:54.885 00 01 00 01 00 30 00 1C CC 1A 30 00 00 00 E4 82 10 C0 08 C8 13 50 6A B0 E9 6F 26 54 D0 6E B9 2D 02 C3 C9 6A
Index: 2 Value: 128
TX: 10:18:54.889 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 E5 4A E2 A7 C8 4C 04 01 50 1F 61 AC C1 47 88 AD B2 3E 48 29 F9 42 51 64 1F 12
RX: 10:18:56.394 00 01 00 01 00 30 00 1A CC 18 30 00 00 00 E5 DB E6 85 52 1F AD 14 C3 FE FD D2 CE A2 62 15 18 8E 80 7A
Index: 3 Value: 0
TX: 10:18:56.397 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 E6 56 43 D2 33 B9 26 64 3C 4B F0 76 47 A4 4F 2B 7C A9 2A 47 10 D9 CA 2B DE B2
RX: 10:18:57.675 00 01 00 01 00 30 00 1C CC 1A 30 00 00 00 E6 5D E8 2E C8 A1 A4 64 22 3E B4 F9 EA 9C 35 3F 44 6E 90 80 F2 51
Index: 4 Value: -1
TX: 10:18:57.679 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 E7 66 92 16 5A BC B3 4A 06 E5 B4 E1 BF 8D E0 76 F5 7E 05 02 76 24 EB 5A 77 CF
RX: 10:18:59.276 00 01 00 01 00 30 00 19 CC 17 30 00 00 00 E7 E0 DF 3E 20 87 4A B0 6A 94 A6 8C F1 D2 73 49 1A 60 7D
Index: 5 Value: true
TX: 10:18:59.279 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 E8 39 A2 D7 EB 8D E3 28 A5 88 D0 E3 14 B7 09 9A 20 56 CA 57 FB D6 C1 71 AD 9F
RX: 10:19:00.876 00 01 00 01 00 30 00 19 CC 17 30 00 00 00 E8 B2 1E BD 9D BE 12 24 68 C4 F8 6F 53 70 42 15 0C 40 64
sujit
1 year 9 months ago
Index: 2 Value: 128
Index: 3 Value: 0
Index: 4 Value: -1
sujit
1 year 9 months ago
Hii kurumi waiting for your…
Hii kurumi waiting for your reply
1 year 8 months ago
Hi, Did you give the block…
Did you give the block cipher and authentication keys to the simulator when you started it? If you didn't it's using the default values.
Can you add the block cipher key? I need it to read the bytes.
sujit
1 year 8 months ago
We are able to connect the…
We are able to connect the meter to create the XML file. However, after some requests, we receive the error: 'java.lang.ArrayIndexOutOfBoundsException: Index 255 out of bounds for length 8.'
Let me know if you need further help!
1 year 8 months ago
Hi, What COSEM object causes…
What COSEM object causes this?
Can you add the send and reply as a hex string? It looks like the meter is returning an invalid enum value, but I need to verify this.
sujit
1 year 8 months ago
hi, COSEM object is Image…
hi,
COSEM object is Image Activation Info
and hex string is
TX: 15:36:50.519 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 E8 39 A2 D7 EB 8D E3 28 A5 88 D0 E3 14 B7 09 9A 20 56 CA 57 FB D6 C1 71 AD 9F
RX: 15:36:51.795 00 01 00 01 00 30 00 19 CC 17 30 00 00 00 E9 D8 44 3A C4 B0 0A A9 90 8B 68 EC C5 AC 6A 7F 08 3A CF
after this i am getting
"Error! Index: 6 Index 255 out of bounds for length 8
java.lang.ArrayIndexOutOfBoundsException: Index 255 out of bounds for length 8" this error
1 year 8 months ago
Hi, I can't decrypt this…
I can't decrypt this because your block cipher key is something else than 000102030405060708090A0B0C0D0E0F. What block cipher key are you using with the last read?
