Sorry for my ignorance but I am new to Gurux. I am trying to read from meter using Gurux component over TCP. I have all required information to do so. I used Gurux Director to successfully read the data, but I have really hard time reproducing what Gurux Director does into Java code. I am trying to combine gurux.dlms.java with gurux.net.java but I cannot find the connection.
Can anyone could point me to the right direction?
Thanks for your reply Mikko. I managed to move forward with it but now I am stuck while adding meter serial number. I have this line of code "dlms.setServerAddress(GXDLMSClient.getServerAddress(32360809));" but this gives me an error "java.lang.StringIndexOutOfBoundsException: String index out of range: -5". Do you know what am I doing wrong?
Reading from meter using TCP
You should try with gurux.dlms.client.example.java.
It's small example that reads all objects from the meter.
You can get that from github.
I did try this and it worked. Do you know what JVM you are using?
I am using below on OS X El Capitan:
java version "1.8.0_121"
Java(TM) SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.121-b13, mixed mode)
What version you are using from gurux.dlms.java?
Make sure that version is 1.4.11
Mikko,
Mikko,
That was it! I had old version in my pom.xml file. Thank you so much!!!
Good to hear that problem is solved.
We just updated new version 2.0.1. Start with that.
