Hello guys.
I'm trying to establish a connection with a meter using GCM (Authentication and Encryption).
AK and EK are all zeros (16 bytes 0x00), System title is "48 45 43 00 05 00 00 01".
Using the manufacturer software I'm able to communicate.
The problem happens in the "parseAareResponse" method, where I get a "invalid tag 97".
This is the configuration I'm doing:
dlms.setUseLogicalNameReferencing(true);
dlms.setInterfaceType(InterfaceType.HDLC);
dlms.setAuthentication(Authentication.HIGH_GMAC);
dlms.getCiphering().setAuthenticationKey(new byte[]{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00});
dlms.getCiphering().setBlockCipherKey(new byte[]{0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00});
dlms.getCiphering().setSystemTitle(new byte[] {0x48, 0x45, 0x43, 0x00, 0x05, 0x00, 0x00, 0x01});
dlms.getCiphering().setSecurity(Security.AUTHENTICATION_ENCRYPTION);
dlms.getCiphering().setFrameCounter(1);
dlms.setClientAddress(0x01);
dlms.setServerAddress(0x7FFF);
dlms is a GXDLMSSecureClient.
Below you can find data log from my software and from the manufacturer software.
I'm clueless about this problem, someone have any idea about how to tackle this?
MANUFACTURER SOFTWARE =====================
Send:
7E A0 23 00 02 FE FF 03 93 E4 B0 81 80 14 05 02 07 D0 06 02 07 D0 07 04 00 00 00 01 08 04 00 00 00 01 3A F2 7E
Receive:
7E A0 21 03 00 02 FE FF 73 CF 15 81 80 14 05 01 C8 06 01 C8 07 04 00 00 00 01 08 04 00 00 00 01 29 C0 7E
Send:
7E A0 69 00 02 FE FF 03 10 26 28 E6 E6 00 60 58 80 02 07 80 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 48 45 43 00 05 00 00 01 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 0A 80 08 0D 7A 76 B7 7F 42 EB 88 BE 22 04 20 21 1E 30 00 00 00 01 70 C1 2E 82 E5 BD 94 94 FE 83 24 3F F2 89 D9 11 A2 52 A0 F3 28 36 89 73 78 53 60 7E
Receive:
7E A0 72 03 00 02 FE FF 30 F1 BF E6 E7 00 61 61 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 48 58 45 11 20 00 0A 44 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 0A 80 08 46 45 41 45 32 41 46 46 BE 23 04 21 28 1F 30 00 00 00 02 40 E9 54 DA 3B A8 90 26 4A AA 75 5A 28 C3 EA 2A E9 B2 3F 95 60 CF 6B D3 C3 DD F0 43 7E
Send:
7E A0 42 00 02 FE FF 03 32 37 3F E6 E6 00 CB 31 30 00 00 00 02 0F F9 3F 90 CB B7 22 C2 0F 98 5B 7B FD FE 56 E4 E5 22 D6 B4 C1 1D 71 49 0B 94 10 94 08 DA 3F 1B 54 3B 87 CB 5D 96 8C B5 E4 8A 8F 35 C2 0A 7E
Receive:
7E A0 3B 03 00 02 FE FF 52 DA 79 E6 E7 00 CF 2A 30 00 00 00 03 B2 8B DF 4C F9 E5 97 C5 15 88 4E D8 57 03 75 FF D3 13 D7 9C 41 C8 B4 7F 1E 02 7B CB 25 9C F6 83 9F 30 DF 30 14 77 3F 7E
Send:
7E A0 2F 00 02 FE FF 03 54 CD B3 E6 E6 00 C8 1E 30 00 00 00 03 C9 52 F6 66 F2 B0 2F B2 BB 6A 99 74 1F E5 CB F1 71 B1 D5 F2 AA 30 B0 81 EC 90 07 7E
Receive:
7E A0 3D 03 00 02 FE FF 74 23 65 E6 E7 00 CC 2C 30 00 00 00 04 48 CF D6 D7 F8 5E 3B 7E 86 72 53 14 3D 8B 12 71 06 CE 2C 2D 94 C8 07 D8 5C 48 C2 3C F3 E1 CE F5 DA 02 FB 6D 9D 33 24 F6 73 7E
Send:
7E A0 0A 00 02 FE FF 03 53 52 54 7E
Receive:
7E A0 0A 03 00 02 FE FF 73 CE 00 7E
MY SOFTWARE =============
Send:
7E A0 0A 00 02 FE FF 03 93 5E 92 7E
Receive:
Send:
7E A0 6B 00 02 FE FF 03 10 9D 1F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 48 45 43 00 05 00 00 01 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 67 22 67 76 1B 5F 46 4E 57 2B 54 28 35 48 5B 57 BE 23 04 21 21 1F 30 00 00 00 02 CD F8 FE 90 C5 E8 3D EE 0F 98 DA 65 03 08 F4 B6 5B E0 DC 04 92 1E 40 E2 66 B2 C2 70 7E
Receive:
7E A0 12 03 00 02 FE FF 30 74 1B E6 E7 00 05 01 C8 81 68 7E
Send:
Received:
Fail to establish connection using GCM
I checked your data. I believe that one of GMAC parameters is wrong.
Check that values are same with your app:
SystemTitle, BlockCipherKey and AuthenticationKey
You have use zero values and I doubt that meter is not use them.
kurumi, thanks for the fast
kurumi, thanks for the fast reply.
I'll look carefully in these parameters, I believe they are right, but since you give me this hint I'll try to look at the decompiled code from the manufacturer to be sure about it.
I have a question though. I was analyzing the bytes and I find it strange that the AARQ generated by gurux don't have the LLC bytes (E6 E6 00) like the manufacturer software has. My DLMS understading is limited, so sorry to ask, but is this correct?
LLC bytes should be there. What version you are using?
My maven pom file have the
My maven pom file have the following configuration:
<dependency>
<groupId>org.gurux</groupId>
<artifactId>gurux.dlms</artifactId>
<version>1.4.11</version>
</dependency>
I have also download the source code from github and it has the same problem.
It is in the class GXDLMS, line 501
if ( !ciphering
&& p.getSettings().getInterfaceType() == InterfaceType.HDLC) {
addLLCBytes(p.getSettings(), reply);
I removed the "!ciphering &&" from the if and now the LLC bytes are present. Although I'm not sure if what I did is safe.
Well, that didn't solve my problem anyway, I'm still getting the invalid tag, but now it is in the "parseApplicationAssociationResponse". I succesfully find where the manufacturer source code uses the security parameters AK/EK/SystemTitle and it is the same I'm using. Well, at least until he calls this gcm dll that I cannot see inside.
Mikko, the version I'm using is the latest? Is it possible that the gcm has some problem?
Thank you for the great help!
You are right. We have fixed this. We try to release new version soon. It's fixed there.
We are using this with several different meters and I don't know that there are any issues with GMAC.
We can verify data what you are sending after next week.
