By Bhaumik, 17 March, 2023 Forums Gurux.Net Hi Mikko, From the meter all values are coming in (W). For the following obis code description is in kW. Obiscode: 0.0.17.0.0.255 Obisdescription: Load Limit Value (kW) Kindly check and update in india.txt file accordingly. Hi Mikko, Can you please… Hi Mikko, Can you please provide an update? Regards, Bhaumik Hi, I have asked this from… Hi, I have asked this from our customers and it seems that some of them are using kW. This is not dedined in Indian Standard 15959 P-2 and for that reason the unit (kW) is removed from the description for the next version. BR, Mikko Log in or register to post comments
Bhaumik
