We are trying to establish a secured connection with security suite 1 and we filled the "Secured Connections" window with the following parameters:
Security : authenticationEncryption
System Title: 41 42 43 44 45 46 47 48
Block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
Authentication key: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
The connection is not working for us, I have a DLMS_ERROR_CODE_INVALID_DECIPHERING_ERROR for the "cip_decrypt" function inside the "apdu_parseUserInformation" function.
Your meter returns Deciphering failed error. It means that your ciphering settings (block cipher or/and authentication keys) are different in the client and the meter.
thank you for your answer but I unfortunately have the same issue also executing the "GuruxDLMSSimpleServerExample" that, as much as I see, uses the default cipher & auth keys. I've found that "cip_crypt" inside "apdu_parseUserInformation" fails returning "DLMS_ERROR_CODE_INVALID_TAG" due to "memcmp(NONSE, input->data + input->size, 12)".
Following I have reported the server log and attached a screenshot with my GXDLMSDirector settings.
Hi Gianluca, Your meter…
Hi Gianluca,
Check those values.
Hi Mikko, thank you for your…
RX: 7E A0 21 02 03 21 93 73 56 81 80 14 05 02 04 00 06 02 04 00 07 04 00 00 00 01 08 04 00 00 00 01 72 E3 7E
svr_isTarget.
Connecting without authentication.
svr_connected to HDLC level.
TX 7E A0 1F 21 02 03 73 D5 E4 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
RX: 7E A0 2C 02 03 21 10 94 9C E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 88 55 7E
svr_validateAuthentication
findObject 15 0.0.40.0.0.255
svr_connected DLMS level.
TX 7E A0 38 21 02 03 30 07 C4 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 00 00 07 1C EA 7E
RX: 7E A0 1A 02 03 21 32 CD 71 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 00 FF 02 00 7D 8F 7E
svr_getAttributeAccess
svr_preRead: 1 0.0.43.1.0.255
svr_postRead: 1 0.0.43.1.0.255
TX 7E A0 16 21 02 03 52 3A 85 E6 E7 00 C4 01 C1 00 06 00 00 00 01 F4 09 7E
RX: 7E A0 08 02 03 21 53 8A A1 7E
svr_disconnected
RX: 7E A0 21 02 03 03 93 F0 46 81 80 14 05 02 04 00 06 02 04 00 07 04 00 00 00 01 08 04 00 00 00 01 72 E3 7E
svr_isTarget.
Connecting using High authentication.
TX 7E A0 1F 03 02 03 73 F0 52 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
RX: 7E A0 6C 02 03 03 10 35 4D E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 00 49 3A 03 79 09 3D 65 6D 64 39 24 33 4E 6D 69 BE 23 04 21 21 1F 31 00 00 00 02 23 7F E0 A9 FA 32 2D DC 9B 2F A1 E3 F6 09 C8 9C 1E 18 3A 16 BB DA 6D 0A 39 6D FE E9 7E
TX 7E A0 10 03 02 03 30 93 48 E6 E7 00 D8 02 05 70 2F 7E
RX: 7E A0 08 02 03 03 53 09 B1 7E
svr_disconnected
svr_preAction: 40 0.0.25.9.0.255
sendPush 40 0.0.25.9.0.255
Thu Feb 2 17:23:00 2023
30 seconds before next invoke Thu Feb 2 17:23:30 2023
30 seconds before next invoke Thu Feb 2 17:24:00 2023
30 seconds before next invoke Thu Feb 2 17:24:30 2023
