I'm not able to read data from objects.
I'm working on new data model in my device. My device is connected via serial line, HDLC.
When I start communication with device through GuruxDLMSDirector the behaviour is :
- connect to device is OK
- reading of Association view from device is OK
- when I'm trying to read object's data, no query is sent to serial line.
It seems that problem is in my data model, but I have no idea, what do with it.
Are you able to recognize, what is in my DLMS data model wrong, that GuruxDLMSDirector doesn't sent the query ?
Look bellow, there is all communication monitored on serial line.
I don't know what you try to read, but the access level for several attributes is zero. Zero means no access and for that reason, data is not read from the meter.
Read the association view with GXDLMSDirector and when you select the object and "Access rights" tab you can see the access rights in a readable format.
THANK YOU A LOT. I already found it.
Have a nice day.
Zdenek
