By poojash, 1 October, 2021 Forums General discussion Hi sir, I want to check is the meter is ON or OFF. So please let me know how I can check using gurux library. Hi, Hi, If the meter is off it doesn't usually answer, some meters have the battery. If you want to check if the power supply is disconnected, you can use Disconnect control for that. BR, Mikko Log in or register to post comments
