Gurux.DLMS.Client.Example.Net_2010
I am new with Gurux projects and I have very little experience with C# too,
but I have found a bug using Gurux.DLMS.Client.Example.Net_2010 project together with Gurux.DLMS.Server.Example_2010.
The bug manifests itself using TCP/IP connection with LN:
Initializing Network connection.
Disconnecting from the meter.
-> 9.22.34 00-01-00-01-00-10-00-02-63-00
Il valore non può essere null.
Nome parametro: value
debugging the code I found the problem is located into the GXCommunication.cs source module at line 273 when "Trace" is enabled and "data" is NULL:
foreach (byte[] it in Client.AARQRequest(null))
if (Trace)
if (data == null)
data = NODATA;
Console.WriteLine("Send AARQ request", BitConverter.ToString(data));
so I suggest one of the possible solutions of the source code as follow:
byte[] NODATA = {};
if (Trace)
if (data == null)
data = NODATA;
reply = ReadDLMSPacket(it);
if (Trace)
if (reply == null)
reply = NODATA;
Console.WriteLine("Parsing AARE reply" + BitConverter.ToString(reply));
Best regard
Franco
Kurumi's picture
Thanks for let us know. You was right.
We changed
to
Console.WriteLine("Send AARQ request", BitConverter.ToString(it));
and fixed this.
We version is in Gurux SVN and Github.
Mikko Kurunsaari
Gurux Ltd
http://www.gurux.fi
